Any suggestions on how to change the displayed values to inch of mercury.
A multiplier(devision) somewhere in the label code? Help with formatting would be welcomed.
Vertical garden barometer
- Franklin97355
Re: Vertical garden barometer
What readings are you getting? Can you post your code>
- TWDM
My clue is working fine after applying a gamma fix, images now display. I have loaded the vertical garden barometer code and it works. It displays pressure as hPa’s. I would like to display the reading as inches of Hg.
The conversation is 1 hPa = 0.0002953 inches of Hg.
I would appreciate any help with modifying the code to output inches of
Hg to three decimal places. This is the out put of an analog barometer.
Thanks for any help.
- TWDM
Attached is the project code.
- Attachments
- code.py
- Project code
- (9.05 KiB) Downloaded 15 times
- adafruit_support_carter
reading_label.text = "Now {:.3f}".format(0.0002953 * reading1)
reading2_label.text = "Last {:.3f}".format(0.0002953 * reading2)
reading3_label.text = "Prev {:.3f}".format(0.0002953 * reading3)
- TWDM
Thank you very much. My conversation number was wrong, it should have been 0.02953. I see the decimal determination number. I will have to some searching about formatting outputs in python. Again thank you.
