CLUE Washed Out Colors
by megrendel on Wed Jan 06, 2021 4:57 pm
I'm coming around on my projects and was working on Adabox015 - the hand washing timer (https://learn.adafruit.com/no-touch-han ... -and-clue/). However, the bitmaps/text are washed out. Otherwise, the unit works fine and colors are clear. Maybe a circuitpython issue? I read some similar issues in the forum but didn't really see an answer outside of getting a replacement unit. Any thoughts? Thanks!
handwash test - Copy.jpg (216.83 KiB) Viewed 278 times
handwash - Copy.jpg (238.18 KiB) Viewed 278 times
megrendel
Re: CLUE Washed Out Colors
by mikeysklar on Fri Jan 08, 2021 3:25 pm
@megrendel,
Have you tried adjusting brightness?
clue.display.brightness = 0.0
clue.display.brightness = 0.8
Does the same test pattern look just as washed out?
Can you try this test pattern? Let me know if you have an issue downloading the UF2.
download/file.php?id=77029
mikeysklar
by adafruit_support_carter on Fri Jan 08, 2021 3:42 pm
Please also try running the four UF2 test files from here:
viewtopic.php?f=65&t=168145&start=45#p825094
and see if you get similar output as shown here:
viewtopic.php?f=65&t=168145&start=60#p825486
by kevinjwalters on Sat Jan 09, 2021 12:12 pm
I see a blue tab on the screen protector. Discussed at tail end of Clue display color issue.
kevinjwalters
by megrendel on Sun Jan 10, 2021 8:28 pm
kevinjwalters wrote:I see a blue tab on the screen protector. Discussed at tail end of Clue display color issue.
Good eye, yes I have the "blue" tab (and would happily take the blue pill right about now)
adafruit_support_carter wrote:Please also try running the four UF2 test files from here:
Not sure what I'm looking for, but it seems they came out fine. Just a little dithering because of the camera.
megrendel
by megrendel on Sun Jan 10, 2021 8:29 pm
Here are the two other tests.
megrendel
by adafruit_support_carter on Mon Jan 11, 2021 12:30 pm
Thanks for testing. Looks like another odd one. Let's just replace it.
Send an email to support@adafruit.com with a link to this thread and your order number and they can send you a replacement CLUE.
by megrendel on Sat Jan 16, 2021 9:04 pm
adafruit_support_carter wrote:Thanks for testing. Looks like another odd one. Let's just replace it.
Thanks, the replacement worked like a charm.
megrendel
