I have yet to understand how I can single-step code on the Clue when using Arduino. I can print messages, but I just wrote a really lousy bug into my code I have no insight into as I cannot even get console messages out.
Any documentation on how to do so?
-Mark
Debugging on Clue
- dastels
Re: Debugging on Clue
At the bottom of https://learn.adafruit.com/adafruit-clue/pinouts the debug connections are pointed out.
This guide (https://learn.adafruit.com/debugging-th ... 1-with-gdb) mwas written for the SAMD21 but should provide a starting point as the interface (SWD) is the same.
- liquidsquid793
Thanks. It would certainly make life easier when I come across problems like the one I created. Doing a re-write from scratch application with a simple real-time task manager and data acquisition/plotting system. My tasker was ported and updated to C++ along the way, and I am not usually a C++ guy though I am pushing myself to learn it (C purist for a long time). I obviously have some more learning to do.
I will see what pod I can dig up that is recommended. I only have JTAG (Xilinx) and older NXP debug pods that probably wont have a compatible API for your tool chains.
- dastels
The SWD is just a simplified JTAG. You're not dependant (as far as I know) on GDB.
