Due to high demand expect some shipping delays at this time, orders may not ship for 3-4 business days.
Fonts for Clue in Arduino
by oldblackcrow on Sat May 15, 2021 5:24 pm
Hi all!
I'm having some difficulty using fonts with the Clue in Arduino IDE. Starting from the beginning, I'm trying to follow this test (https://learn.adafruit.com/creating-cus ... lay-sketch) to move forward, but I keep getting an error.
//Uncomment only one of the following lines to select your display.
#define USE_ILI9341   //2.4 inch 320x240 TFT Feather Wing
//#define USE_HX8357    //3.5 inch 480x320 TFT Feather Wing
//#define USE_HALLOWING //Adafruit Hallowing M0 Express
//#define USE_PYGAMER   //Adafruit PyGamer
#include "board_select.h"
#define STMPE_CS 6
#define TFT_CS   9
#define TFT_DC   10
#define SD_CS    5
I've uncommented each one individually while commenting out the ones I'm not using but they all fail with the following message:
Arduino: 1.8.13 (Windows 10), Board: "Adafruit CLUE, 0.3.2 SoftDevice s140 6.1.1, Level 0 (Release)"
Font-Testing001:1:10: fatal error: board_select.h: No such file or directory
1 | #include "board_select.h"
compilation terminated.
exit status 1
Is there a workaround for this? Thanks so much!
oldblackcrow
Re: Fonts for Clue in Arduino
by blnkjns on Sun May 16, 2021 2:56 am
You get the errors because you don't have a 240x320 Featherwing display, but a built in 240x240 1,3inch IPS one.
Go to Tools->Libraries->Library Manager and search for:
Adafruit ST7735
Install it, go to the sample files under File->examples->Adafruit ST7735 and choose Graphicstest and change the comments as follows:
// For 1.44" and 1.8" TFT with ST7735 use:
//Adafruit_ST7735 tft = Adafruit_ST7735(TFT_CS, TFT_DC, TFT_RST);
// For 1.14", 1.3", 1.54", and 2.0" TFT with ST7789:
// Adafruit_ST7789 tft = Adafruit_ST7789(TFT_CS, TFT_DC, TFT_RST);
Also the SPI pins are different, so we need to change that too.
P0.12 = CS
P0.13 = DC
P0.14 = SCK
P0.15 = MOSI
P1.03 = RESET
P1.05 = Backlight
But these are port-numbers, not Arduino code pin numbers. I will replace them with the correct Arduino numbers below.
Now change this line:
// OR for the ST7789-based displays, we will use this call
//Adafruit_ST7789 tft = Adafruit_ST7789(TFT_CS, TFT_DC, TFT_MOSI, TFT_SCLK, TFT_RST);
to
#define CLUE_CS   31
#define CLUE_DC   32
#define CLUE_MOSI 30
#define CLUE_SCK  29
#define CLUE_RST  33
Adafruit_ST7789 tft = Adafruit_ST7789(CLUE_CS, CLUE_DC, CLUE_MOSI, CLUE_SCK, CLUE_RST);
Try running the sample sketch, and if that works, start messing with the fonts from there.
If you don't get errors, but don't see much, we might need to put on the backlight manually as well.
I've no CLUE if this works ;) , only a PyBadge, where I do something similar, but with different pin numbers.
blnkjns
by oldblackcrow on Sun May 16, 2021 7:09 pm
Thank you for helping me with this! I'm a bit confused though, as there are several lines that seem to be in conflict. Here's the entire code:
  This is a library for several Adafruit displays based on ST77* drivers.
  Works with the Adafruit 1.8" TFT Breakout w/SD card
    ----> http://www.adafruit.com/products/358
  The 1.8" TFT shield
    ----> https://www.adafruit.com/product/802
  The 1.44" TFT breakout
    ----> https://www.adafruit.com/product/2088
  The 1.14" TFT breakout
  ----> https://www.adafruit.com/product/4383
  The 1.3" TFT breakout
  ----> https://www.adafruit.com/product/4313
  The 1.54" TFT breakout
    ----> https://www.adafruit.com/product/3787
  The 2.0" TFT breakout
    ----> https://www.adafruit.com/product/4311
  as well as Adafruit raw 1.8" TFT display
    ----> http://www.adafruit.com/products/618
  Check out the links above for our tutorials and wiring diagrams.
  These displays use SPI to communicate, 4 or 5 pins are required to
  interface (RST is optional).
  products from Adafruit!
  MIT license, all text above must be included in any redistribution
#include <Adafruit_GFX.h>    // Core graphics library
#include <Adafruit_ST7735.h> // Hardware-specific library for ST7735
#include <Adafruit_ST7789.h> // Hardware-specific library for ST7789
#include <SPI.h>
#if defined(ARDUINO_FEATHER_ESP32) // Feather Huzzah32
  #define TFT_CS         14
  #define TFT_RST        15
  #define TFT_DC         32
#elif defined(ESP8266)
  #define TFT_CS         4
  #define TFT_RST        16
  #define TFT_DC         5
#else
  // For the breakout board, you can use any 2 or 3 pins.
  // These pins will also work for the 1.8" TFT shield.
  #define TFT_CS        10
  #define TFT_RST        9 // Or set to -1 and connect to Arduino RESET pin
  #define TFT_DC         8
#endif
// OPTION 1 (recommended) is to use the HARDWARE SPI pins, which are unique
// to each board and not reassignable. For Arduino Uno: MOSI = pin 11 and
// SCLK = pin 13. This is the fastest mode of operation and is required if
// using the breakout board's microSD card.
//Adafruit_ST7789 tft = Adafruit_ST7789(TFT_CS, TFT_DC, TFT_RST);
// OPTION 2 lets you interface the display using ANY TWO or THREE PINS,
// tradeoff being that performance is not as fast as hardware SPI above.
//#define TFT_MOSI 11  // Data out
//#define TFT_SCLK 13  // Clock out
// For ST7735-based displays, we will use this call
//Adafruit_ST7735 tft = Adafruit_ST7735(TFT_CS, TFT_DC, TFT_MOSI, TFT_SCLK, TFT_RST);
float p = 3.1415926;
void setup(void) {
  Serial.begin(9600);
  Serial.print(F("Hello! ST77xx TFT Test"));
  // Use this initializer if using a 1.8" TFT screen:
  tft.initR(INITR_BLACKTAB);      // Init ST7735S chip, black tab
  // OR use this initializer if using a 1.8" TFT screen with offset such as WaveShare:
  // tft.initR(INITR_GREENTAB);      // Init ST7735S chip, green tab
  // OR use this initializer (uncomment) if using a 1.44" TFT:
  //tft.initR(INITR_144GREENTAB); // Init ST7735R chip, green tab
  // OR use this initializer (uncomment) if using a 0.96" 160x80 TFT:
  //tft.initR(INITR_MINI160x80);  // Init ST7735S mini display
  // OR use this initializer (uncomment) if using a 1.3" or 1.54" 240x240 TFT:
  //tft.init(240, 240);           // Init ST7789 240x240
  // OR use this initializer (uncomment) if using a 2.0" 320x240 TFT:
  //tft.init(240, 320);           // Init ST7789 320x240
  // OR use this initializer (uncomment) if using a 1.14" 240x135 TFT:
  //tft.init(135, 240);           // Init ST7789 240x135
  // SPI speed defaults to SPI_DEFAULT_FREQ defined in the library, you can override it here
  // Note that speed allowable depends on chip and quality of wiring, if you go too fast, you
  // may end up with a black screen some times, or all the time.
  //tft.setSPISpeed(40000000);
  Serial.println(F("Initialized"));
  uint16_t time = millis();
  tft.fillScreen(ST77XX_BLACK);
  time = millis() - time;
  Serial.println(time, DEC);
  delay(500);
  // large block of text
  testdrawtext("Lorem ipsum dolor sit amet, consectetur adipiscing elit. Curabitur adipiscing ante sed nibh tincidunt feugiat. Maecenas enim massa, fringilla sed malesuada et, malesuada sit amet turpis. Sed porttitor neque ut ante pretium vitae malesuada nunc bibendum. Nullam aliquet ultrices massa eu hendrerit. Ut sed nisi lorem. In vestibulum purus a tortor imperdiet posuere. ", ST77XX_WHITE);
  delay(1000);
  // tft print function!
  tftPrintTest();
  delay(4000);
  // a single pixel
  tft.drawPixel(tft.width()/2, tft.height()/2, ST77XX_GREEN);
  delay(500);
  // line draw test
  testlines(ST77XX_YELLOW);
  delay(500);
  // optimized lines
  testfastlines(ST77XX_RED, ST77XX_BLUE);
  delay(500);
  testdrawrects(ST77XX_GREEN);
  delay(500);
  testfillrects(ST77XX_YELLOW, ST77XX_MAGENTA);
  delay(500);
  testfillcircles(10, ST77XX_BLUE);
  testdrawcircles(10, ST77XX_WHITE);
  delay(500);
  testroundrects();
  delay(500);
  testtriangles();
  delay(500);
  mediabuttons();
  delay(500);
  Serial.println("done");
  delay(1000);
  tft.invertDisplay(true);
  delay(500);
  tft.invertDisplay(false);
  delay(500);
void testlines(uint16_t color) {
  for (int16_t x=0; x < tft.width(); x+=6) {
    tft.drawLine(0, 0, x, tft.height()-1, color);
    delay(0);
  for (int16_t y=0; y < tft.height(); y+=6) {
    tft.drawLine(0, 0, tft.width()-1, y, color);
    delay(0);
    tft.drawLine(tft.width()-1, 0, x, tft.height()-1, color);
    delay(0);
    tft.drawLine(tft.width()-1, 0, 0, y, color);
    delay(0);
    tft.drawLine(0, tft.height()-1, x, 0, color);
    delay(0);
    tft.drawLine(0, tft.height()-1, tft.width()-1, y, color);
    delay(0);
    tft.drawLine(tft.width()-1, tft.height()-1, x, 0, color);
    delay(0);
    tft.drawLine(tft.width()-1, tft.height()-1, 0, y, color);
    delay(0);
void testdrawtext(char *text, uint16_t color) {
  tft.setCursor(0, 0);
  tft.setTextColor(color);
  tft.setTextWrap(true);
  tft.print(text);
void testfastlines(uint16_t color1, uint16_t color2) {
  for (int16_t y=0; y < tft.height(); y+=5) {
    tft.drawFastHLine(0, y, tft.width(), color1);
  for (int16_t x=0; x < tft.width(); x+=5) {
    tft.drawFastVLine(x, 0, tft.height(), color2);
void testdrawrects(uint16_t color) {
    tft.drawRect(tft.width()/2 -x/2, tft.height()/2 -x/2 , x, x, color);
void testfillrects(uint16_t color1, uint16_t color2) {
  for (int16_t x=tft.width()-1; x > 6; x-=6) {
    tft.fillRect(tft.width()/2 -x/2, tft.height()/2 -x/2 , x, x, color1);
    tft.drawRect(tft.width()/2 -x/2, tft.height()/2 -x/2 , x, x, color2);
void testfillcircles(uint8_t radius, uint16_t color) {
  for (int16_t x=radius; x < tft.width(); x+=radius*2) {
    for (int16_t y=radius; y < tft.height(); y+=radius*2) {
      tft.fillCircle(x, y, radius, color);
void testdrawcircles(uint8_t radius, uint16_t color) {
  for (int16_t x=0; x < tft.width()+radius; x+=radius*2) {
    for (int16_t y=0; y < tft.height()+radius; y+=radius*2) {
      tft.drawCircle(x, y, radius, color);
void testtriangles() {
  uint16_t color = 0xF800;
  int t;
  int w = tft.width()/2;
  int x = tft.height()-1;
  int y = 0;
  int z = tft.width();
  for(t = 0 ; t <= 15; t++) {
    tft.drawTriangle(w, y, y, x, z, x, color);
    x-=4;
    y+=4;
    z-=4;
    color+=100;
void testroundrects() {
  uint16_t color = 100;
  int i;
  int t;
  for(t = 0 ; t <= 4; t+=1) {
    int x = 0;
    int y = 0;
    int w = tft.width()-2;
    int h = tft.height()-2;
    for(i = 0 ; i <= 16; i+=1) {
      tft.drawRoundRect(x, y, w, h, 5, color);
      x+=2;
      y+=3;
      w-=4;
      h-=6;
      color+=1100;
    color+=100;
void tftPrintTest() {
  tft.setTextWrap(false);
  tft.setCursor(0, 30);
  tft.setTextColor(ST77XX_RED);
  tft.setTextSize(1);
  tft.println("Hello World!");
  tft.setTextColor(ST77XX_YELLOW);
  tft.setTextSize(2);
  tft.setTextColor(ST77XX_GREEN);
  tft.setTextSize(3);
  tft.setTextColor(ST77XX_BLUE);
  tft.setTextSize(4);
  tft.print(1234.567);
  delay(1500);
  tft.setTextColor(ST77XX_WHITE);
  tft.setTextSize(0);
  tft.setTextSize(1);
  tft.print(p, 6);
  tft.println(" Want pi?");
  tft.println(" ");
  tft.print(8675309, HEX); // print 8,675,309 out in HEX!
  tft.println(" Print HEX!");
  tft.println(" ");
  tft.println("Sketch has been");
  tft.println("running for: ");
  tft.setTextColor(ST77XX_MAGENTA);
  tft.print(millis() / 1000);
  tft.print(" seconds.");
void mediabuttons() {
  // play
  tft.fillRoundRect(25, 10, 78, 60, 8, ST77XX_WHITE);
  tft.fillTriangle(42, 20, 42, 60, 90, 40, ST77XX_RED);
  delay(500);
  // pause
  tft.fillRoundRect(25, 90, 78, 60, 8, ST77XX_WHITE);
  tft.fillRoundRect(39, 98, 20, 45, 5, ST77XX_GREEN);
  tft.fillRoundRect(69, 98, 20, 45, 5, ST77XX_GREEN);
  delay(500);
  // play color
  tft.fillTriangle(42, 20, 42, 60, 90, 40, ST77XX_BLUE);
  delay(50);
  // pause color
  tft.fillRoundRect(39, 98, 20, 45, 5, ST77XX_RED);
  tft.fillRoundRect(69, 98, 20, 45, 5, ST77XX_RED);
  // play color
  tft.fillTriangle(42, 20, 42, 60, 90, 40, ST77XX_GREEN);
Here's what I understood the changes to be:
#include <SPI.h>
  #define TFT_CS         14
  #define TFT_RST        15
  #define TFT_DC         32
  #define TFT_CS         4
  #define TFT_RST        16
  #define TFT_DC         5
#else
  #define TFT_CS        10
  #define TFT_DC         8
#endif
#define CLUE_CS   31
#define CLUE_DC   32
#define CLUE_SCK  29
#define CLUE_RST  33
void setup(void) {
  Serial.begin(9600);
  delay(500);
  delay(1000);
  tftPrintTest();
  delay(4000);
  // a single pixel
  delay(500);
  // line draw test
  delay(500);
  // optimized lines
  delay(500);
  delay(500);
  delay(500);
  delay(500);
  testroundrects();
  delay(500);
  testtriangles();
  delay(500);
  mediabuttons();
  delay(500);
  delay(1000);
  delay(500);
  delay(500);
    delay(0);
    delay(0);
    delay(0);
    delay(0);
    delay(0);
    delay(0);
    delay(0);
    delay(0);
  tft.print(text);
  int t;
  int y = 0;
    x-=4;
    y+=4;
    z-=4;
    color+=100;
  int i;
  int t;
    int x = 0;
    int y = 0;
      x+=2;
      y+=3;
      w-=4;
      h-=6;
      color+=1100;
    color+=100;
  tft.setTextSize(1);
  tft.setTextSize(2);
  tft.setTextSize(3);
  tft.setTextSize(4);
  delay(1500);
  tft.setTextSize(0);
  tft.setTextSize(1);
  tft.print(p, 6);
  tft.println(" ");
  tft.println(" ");
  // play
  delay(500);
  // pause
  delay(500);
  // play color
  delay(50);
  // pause color
  // play color
I get the following error:
graphicstest:56:17: error: conflicting declaration 'Adafruit_ST7789 tft'
56 | Adafruit_ST7789 tft = Adafruit_ST7789(CLUE_CS, CLUE_DC, CLUE_MOSI, CLUE_SCK, CLUE_RST);
C:\Users\brian\AppData\Local\Temp\arduino_modified_sketch_44124\graphicstest.ino:36:17: note: previous declaration as 'Adafruit_ST7735 tft'
36 | Adafruit_ST7735 tft = Adafruit_ST7735(TFT_CS, TFT_DC, TFT_RST);
exit status 1
I'm probably doing something wrong, but I don't know what. Thanks again!
oldblackcrow
by blnkjns on Sun May 16, 2021 11:28 pm
You have to uncomment the second line by placing // in front. The display is a 7789
blnkjns
by oldblackcrow on Mon May 17, 2021 4:50 pm
Ok... I fixed that and a few more errors I found and this is the code with no errors:
#include <SPI.h>
  #define TFT_CS         14
  #define TFT_RST        15
  #define TFT_DC         32
  #define TFT_CS         4
  #define TFT_RST        16
  #define TFT_DC         5
#else
  #define TFT_CS        10
  #define TFT_DC         8
#endif
// Adafruit_ST7735 tft = Adafruit_ST7735(TFT_CS, TFT_DC, TFT_RST);
#define CLUE_CS   31
#define CLUE_DC   32
#define CLUE_SCK  29
#define CLUE_RST  33
void setup(void) {
  Serial.begin(9600);
  //tft.initR(INITR_BLACKTAB);      // Init ST7735S chip, black tab
  delay(500);
  delay(1000);
  tftPrintTest();
  delay(4000);
  // a single pixel
  delay(500);
  // line draw test
  delay(500);
  // optimized lines
  delay(500);
  delay(500);
  delay(500);
  delay(500);
  testroundrects();
  delay(500);
  testtriangles();
  delay(500);
  mediabuttons();
  delay(500);
  delay(1000);
  delay(500);
  delay(500);
    delay(0);
    delay(0);
    delay(0);
    delay(0);
    delay(0);
    delay(0);
    delay(0);
    delay(0);
  tft.print(text);
  int t;
  int y = 0;
    x-=4;
    y+=4;
    z-=4;
    color+=100;
  int i;
  int t;
    int x = 0;
    int y = 0;
      x+=2;
      y+=3;
      w-=4;
      h-=6;
      color+=1100;
    color+=100;
  tft.setTextSize(1);
  tft.setTextSize(2);
  tft.setTextSize(3);
  tft.setTextSize(4);
  delay(1500);
  tft.setTextSize(0);
  tft.setTextSize(1);
  tft.print(p, 6);
  tft.println(" ");
  tft.println(" ");
  // play
  delay(500);
  // pause
  delay(500);
  // play color
  delay(50);
  // pause color
  // play color
Unfortunately, I just get a black screen... any ideas? Thanks!
oldblackcrow
by oldblackcrow on Mon May 17, 2021 5:08 pm
Well, I got the Arcada graphics test to work... So I'll go from there?
oldblackcrow
by blnkjns on Tue May 18, 2021 6:25 am
Yes. it is best to strip all code from a demo to the point that you can just write a text in font X to a certain position, and then merge that with other code that takes care of other parts of your final goals.
blnkjns
by karelv on Thu May 20, 2021 6:55 pm
Such a stripped project would be very helpful, something that simply works!
karelv
