Can I use CLUE with the fingerprint sensor?
by dkanday on Mon Jun 14, 2021 10:50 am
I am thinking of using the CLUE with the adafruit fingerprint sensor: https://learn.adafruit.com/adafruit-opt ... r/overview.
Wanted to know if that is possible and also I see that the fingerprint sensor needs the UART pins but those pins are missing on the CLUE. Iam trying to avoid using an audrino or a raspberry pi.
Also in the example, it says that I need to add the follwoing section :
# If using with a computer such as Linux/RaspberryPi, Mac, Windows with USB/serial converter:
# import serial
# uart = serial.Serial("/dev/ttyUSB0", baudrate=57600, timeout=1)
I tried installing the serial library from the audrino website, but the clue keeps looking for the serial library in the lib folder and I am not able to find serial library for the clue.
Any help would be greatly apprecaited.
dkanday
Re: Can I use CLUE with the fingerprint sensor?
by jerryn on Mon Jun 14, 2021 11:12 am
According to the Pinout the pinouts - the RX/TX are on the #0/#1 pads https://learn.adafruit.com/adafruit-clue/pinouts
You should be able to connect the fingerprint sensor to those.
Then use the Circuitptyhon example https://learn.adafruit.com/adafruit-optical-fingerprint-sensor/circuitpython#example-code-3044769-20 its does not use "serial"
It uses busio.UART
Note: I have not tried this myself and I don't represent Adafruit. Just trying to help.
jerryn
by jerryn on Mon Jun 14, 2021 11:57 am
FYI - I hooked up one of the R503 Fingeprint sensors to my CLUE as above and it worked. I did have to make one change to the code.
CircuitPython does not accept the "flush=True" argument to the Print commands so I had to remove them all.
Otherwise it worked normally.
here is the modified fingerprint_simpletest.py that I used
# SPDX-FileCopyrightText: 2021 ladyada for Adafruit Industries
import time
import board
import busio
from digitalio import DigitalInOut, Direction
import adafruit_fingerprint
led = DigitalInOut(board.D13)
led.direction = Direction.OUTPUT
uart = busio.UART(board.TX, board.RX, baudrate=57600)
# import serial
# If using with Linux/Raspberry Pi and hardware UART:
# import serial
# uart = serial.Serial("/dev/ttyS0", baudrate=57600, timeout=1)
finger = adafruit_fingerprint.Adafruit_Fingerprint(uart)
def get_fingerprint():
    """Get a finger print image, template it, and see if it matches!"""
    print("Waiting for image...")
    while finger.get_image() != adafruit_fingerprint.OK:
        pass
    print("Templating...")
    if finger.image_2_tz(1) != adafruit_fingerprint.OK:
        return False
    print("Searching...")
    if finger.finger_search() != adafruit_fingerprint.OK:
        return False
    return True
# pylint: disable=too-many-branches
def get_fingerprint_detail():
    This time, print out each error instead of just returning on failure"""
    print("Getting image...", end="")
    i = finger.get_image()
    if i == adafruit_fingerprint.OK:
        print("Image taken")
    else:
        if i == adafruit_fingerprint.NOFINGER:
            print("No finger detected")
        elif i == adafruit_fingerprint.IMAGEFAIL:
            print("Imaging error")
        else:
            print("Other error")
        return False
    print("Templating...", end="")
    i = finger.image_2_tz(1)
        print("Templated")
    else:
        if i == adafruit_fingerprint.IMAGEMESS:
            print("Image too messy")
        elif i == adafruit_fingerprint.FEATUREFAIL:
            print("Could not identify features")
        elif i == adafruit_fingerprint.INVALIDIMAGE:
            print("Image invalid")
        else:
        return False
    print("Searching...", end="")
    i = finger.finger_fast_search()
    # pylint: disable=no-else-return
    # This block needs to be refactored when it can be tested.
        print("Found fingerprint!")
        return True
    else:
        if i == adafruit_fingerprint.NOTFOUND:
            print("No match found")
        else:
        return False
# pylint: disable=too-many-statements
def enroll_finger(location):
    """Take a 2 finger images and template it, then store in 'location'"""
    for fingerimg in range(1, 3):
        if fingerimg == 1:
            print("Place finger on sensor...", end="")
        else:
            print("Place same finger again...", end="")
        while True:
                break
                print(".", end="")
                return False
            else:
                return False
        i = finger.image_2_tz(fingerimg)
            print("Templated")
        else:
            else:
            return False
        if fingerimg == 1:
            print("Remove finger")
            time.sleep(1)
            while i != adafruit_fingerprint.NOFINGER:
    print("Creating model...", end="")
    i = finger.create_model()
        print("Created")
    else:
        if i == adafruit_fingerprint.ENROLLMISMATCH:
            print("Prints did not match")
        else:
        return False
    print("Storing model #%d..." % location, end="")
    i = finger.store_model(location)
        print("Stored")
    else:
        if i == adafruit_fingerprint.BADLOCATION:
            print("Bad storage location")
        elif i == adafruit_fingerprint.FLASHERR:
            print("Flash storage error")
        else:
        return False
    return True
def get_num():
    """Use input() to get a valid number from 1 to 127. Retry till success!"""
    i = 0
    while (i > 127) or (i < 1):
        try:
            i = int(input("Enter ID # from 1-127: "))
        except ValueError:
            pass
    return i
while True:
    print("----------------")
    if finger.read_templates() != adafruit_fingerprint.OK:
        raise RuntimeError("Failed to read templates")
    print("Fingerprint templates:", finger.templates)
    print("e) enroll print")
    print("f) find print")
    print("d) delete print")
    c = input("> ")
    if c == "e":
        enroll_finger(get_num())
    if c == "f":
        if get_fingerprint():
            print("Detected #", finger.finger_id, "with confidence", finger.confidence)
        else:
            print("Finger not found")
    if c == "d":
        if finger.delete_model(get_num()) == adafruit_fingerprint.OK:
            print("Deleted!")
        else:
            print("Failed to delete")
jerryn
by jerryn on Mon Jun 14, 2021 1:40 pm
An update on the "flush" argument. It turns out that it is a bug in CircuitPython. See this issue for progress on fixing it https://github.com/adafruit/circuitpython/issues/4888.
For now , you can just remove the "flush" arguments as I noted.
jerryn
by dkanday on Wed Jun 16, 2021 4:58 pm
Thanks Jerryn
dkanday
by dkanday on Thu Jun 17, 2021 4:54 pm
Hi Jerryn,
I am trying to use the R503 fingerprint sensor with the clue(modified audrino code). The way I am implementing the code is when I press the left button or button A, I enroll the user and when pressing the button B, I search for the fingerprint.
The issue I am facing is when I store a fingerprint, it says stored successfully and when I tried to read back the same fingerprint it says unknown fingerprint.
The reason I have modified is to remove unwanted data and also I removed the ID# as I cannot input an ID into it.(attached is the code for reference)
But when I run the default example code on the UNO, it stores the data correctly.
Questions:
1. Can removing the ID cause an issue? if not what can cause this error.
2. Also can I have a built in counter where it remembers the last known ID which the finger print got associated to and when I enroll it, the ID increments by itself?
Any help is greatly appreciated.
v7_06172021.ino
(21.99 KiB) Downloaded 7 times
dkanday
by jerryn on Fri Jun 18, 2021 6:18 am
There is a lot going on in your example and it is hard for me to follow it clearly especially with ll the commented code.
Also, I have not used the Arduino Library so I am not familiar with it. I have been working under CircuitPython.
However, if you comment out the finger.storemode call as you have
 // p = finger.storeModel(id); // D v6 commenting this line
it is not clear that you are actually storing the fingerprint in the reader.
I would suggest trying to simplify the example to debug the fingerprint sensor operation.
It is good to know that the library examples work OK.
jerryn
by dkanday on Fri Jun 18, 2021 11:18 am
Hi Jerryn,
enabling the section mentioned in the code and modifying made it work. Thanks for the suggestion :)
dkanday
by jerryn on Fri Jun 18, 2021 12:39 pm
Great! Glad it is working.
Good luck with your project!
jerryn
by dkanday on Fri Jun 25, 2021 10:10 am
Hi jerryn,
Were you able to turn on and off the LEDs on the sensor? I am having trouble understanding how to do that.
dkanday
by jerryn on Fri Jun 25, 2021 12:13 pm
I have not used the Arduino Library -- I have only used the R503 with Circuitpython. The LED works with Circuitpython.
With Arduino, I think you use the LEDcontrol function https://github.com/adafruit/Adafruit-Fingerprint-Sensor-Library/blob/master/Adafruit_Fingerprint.cpp#L339
Have you tried this example? I am not sure if it is for the R503 https://github.com/adafruit/Adafruit-Fingerprint-Sensor-Library/blob/master/examples/ledcontrol/ledcontrol.ino
jerryn
by dkanday on Fri Jun 25, 2021 5:10 pm
Thanks.. let me try that out.
dkanday
by dkanday on Mon Jun 28, 2021 11:42 am
Thanks Jerryn,
That example worked for me.
dkanday
