Egg Drop Clue White Screen
OSCEDU2022
Post by OSCEDU2022 »
Hello, I just purchased 6 clues to do egg drop. I downloaded all the codes to one of them and it has sound and everything but the egg on the screen looks whiteish. Is there a way to fix this or does this mean malfunction of the screen?
Franklin97355
Re: Egg Drop Clue White Screen
Post by Franklin97355 »
Have you tried the codes to see if the other ones react the same? Which code did you use?
OSCEDU2022
3 of the 6 that I purchased have white screens. I am using the code provided by adafruit for egg drop.
Franklin97355
Can you post a picture of the problem?
OSCEDU2022
The screen is white and you can barely see the egg picture.
adafruit_support_carter
Try the pre-compiled test UF2 from here and see if it also appears different on those CLUEs:
https://learn.adafruit.com/adafruit-clue/arduino-test
You don't need Arduino installed. Just download the UF2 file, double click reset on CLUE to get BOOT folder, then drag UF2 to BOOT folder.
adafruit2
Post by adafruit2 »
we think this is a weird artifact with gamma correction on some screens, but it is fixable in software we think!
OSCEDU2022
The screen is still white after UF2. Is there anything else to fix this or should I request a replacement?
adafruit2
Post by adafruit2 »
on all 6 CLUE? or how many?
OSCEDU2022
3 of them
adafruit2
Post by adafruit2 »
ok thats really odd - can you flip the boards over and take a photo of the TFT connector? it sounds like maybe they got loose. 3 boards is a lot to have this very rare issue, which makes us think it could be something else. the other 3 boards loaded that UF2 just fine?
OSCEDU2022
These are the ones with the white screen. The other 3 clues work perfectly.
adafruit2
Post by adafruit2 »
quite odd! ok lets replace them. email support@adafruit with a link to this thread and if you are in the USA, please RMA "FORPHIL" - so we can investigate em - thanks :)
Return to “CLUE Board”
