After replacing demoboot bin with adafruit-wippersnapper-esp32s2-magtag-1-0-0-beta.3.uf2 from bootloader mode, the first reset results in solid red indictors.
Subsequent resets result in a flash of blue/cyan followed by a reset.
The WIPPER drive appears briefly.
Same process (with proper .uf2) works fine for FunHouse.
The MagTag is the newer version w/ black mask.
https://www.adafruit.com/product/4819
Bootloop on Magtag
- brubell
- Learn User Page
Re: Bootloop on Magtag
Did you have the same issue with loading beta.2 (attached)?
- Attachments
- adafruit-wippersnapper-esp32s2-magtag-1-0-0-beta+2.uf2
- (1.83 MiB) Downloaded 26 times
- brubell
- Learn User Page
Also, which operating system is on your host PC?
- ceedon
Win10. Will try loading the other file later today.
- ceedon
Same behavior in the loop. Green+Blue lights flash -> reset. No solid red first time, though.
- brubell
- Learn User Page
What's the output of the 'wippersnapper_boot_out.txt' file on the WIPPER drive?ceedon wrote:Same behavior in the loop. Green+Blue lights flash -> reset. No solid red first time, though.
- ceedon
It doesn't stay up long enough to grab it. Any tips to work around that? Can figure out a script if not.
Can try from linux as well. Haven't done so yet.
- shamste
I'm having the same issues with Beta.2 and Beta.3.
- scottlnrd
I'm having the same issue as well. I'm loading it from a Mac running latest OS.
- brubell
- Learn User Page
Also with MagTag?shamste wrote:I'm having the same issues with Beta.2 and Beta.3.
- brubell
- Learn User Page
Also with MagTag?scottlnrd wrote:I'm having the same issue as well. I'm loading it from a Mac running latest OS.
- scottlnrd
I completely erased my MagTag and started from scratch. After I drag the Wippersnapper beta onto the drive and it reboots, the Magtag flashes it's LEDs two blueish colors for several times until it finally stops the cycle, ending in all red LEDs. But never mounts the drive long enough to see anything on it.
- brubell
- Learn User Page
Any luck on Linux?ceedon wrote:It doesn't stay up long enough to grab it. Any tips to work around that? Can figure out a script if not.
- scottlnrd
I don't think this is an issue of what OS it's running from. It would seem to be a boot loader issue from the wippersnapper uf2 file. There are also at least a couple revisions of this device if I'm reading correctly. Could it be that wippersnapper only works on one of them?
