ESP8266 NodeMCU V3
ESP8266 NodeMCU V3
by Giguere81 on Fri Jul 01, 2022 3:17 am
So I have 3 ESP8266 NodeMCU V3 I am trying to connect to THE IoT using Arduino IO but how do I do this? Ito only lists 19 boards that are compatible and esp8266 is not one of them
Giguere81
Re: ESP8266 NodeMCU V3
by tepalia02 on Fri Jul 01, 2022 4:35 am
Hello, sorry I could not understand where you are being unable to find the board. Are you using the Arduino IDE or anything else?
tepalia02
by brubell on Fri Jul 01, 2022 11:59 am
Giguere81 wrote:So I have 3 ESP8266 NodeMCU V3 I am trying to connect to THE IoT using Arduino IO but how do I do this? Ito only lists 19 boards that are compatible and esp8266 is not one of them
The NodeMCU V3 is not a compatible board, but the ESP8266 architecture is supported by Adafruit IO Arduino.
You'd need to add a new board to WipperSnapper by following this guide: https://learn.adafruit.com/how-to-add-a ... persnapper
brubell
