Bootloop on Magtag
adafruit.io wippersnapper BETA support, discussions, and more!
ceedon
Bootloop on Magtag
Post by ceedon »
After replacing demoboot bin with adafruit-wippersnapper-esp32s2-magtag-1-0-0-beta.3.uf2 from bootloader mode, the first reset results in solid red indictors.
Subsequent resets result in a flash of blue/cyan followed by a reset.
The WIPPER drive appears briefly.
Same process (with proper .uf2) works fine for FunHouse.
The MagTag is the newer version w/ black mask.
https://www.adafruit.com/product/4819
brubell
Learn User Page
Re: Bootloop on Magtag
Post by brubell »
Did you have the same issue with loading beta.2 (attached)?
adafruit-wippersnapper-esp32s2-magtag-1-0-0-beta+2.uf2
(1.83 MiB) Downloaded 7 times
brubell
Learn User Page
Post by brubell »
Also, which operating system is on your host PC?
ceedon
Post by ceedon »
Win10. Will try loading the other file later today.
ceedon
Post by ceedon »
Same behavior in the loop. Green+Blue lights flash -> reset. No solid red first time, though.
brubell
Learn User Page
Post by brubell »
ceedon wrote:Same behavior in the loop. Green+Blue lights flash -> reset. No solid red first time, though.
What's the output of the 'wippersnapper_boot_out.txt' file on the WIPPER drive?
ceedon
Post by ceedon »
It doesn't stay up long enough to grab it. Any tips to work around that? Can figure out a script if not.
Can try from linux as well. Haven't done so yet.
shamste
Post by shamste »
I'm having the same issues with Beta.2 and Beta.3.
scottlnrd
Post by scottlnrd »
I'm having the same issue as well. I'm loading it from a Mac running latest OS.
brubell
Learn User Page
Post by brubell »
shamste wrote:I'm having the same issues with Beta.2 and Beta.3.
Also with MagTag?
brubell
Learn User Page
Post by brubell »
scottlnrd wrote:I'm having the same issue as well. I'm loading it from a Mac running latest OS.
Also with MagTag?
scottlnrd
Post by scottlnrd »
Yes, MagTag.
scottlnrd
Post by scottlnrd »
I completely erased my MagTag and started from scratch. After I drag the Wippersnapper beta onto the drive and it reboots, the Magtag flashes it's LEDs two blueish colors for several times until it finally stops the cycle, ending in all red LEDs. But never mounts the drive long enough to see anything on it.
brubell
Learn User Page
Post by brubell »
ceedon wrote:It doesn't stay up long enough to grab it. Any tips to work around that? Can figure out a script if not.
Any luck on Linux?
scottlnrd
Post by scottlnrd »
I don't think this is an issue of what OS it's running from. It would seem to be a boot loader issue from the wippersnapper uf2 file. There are also at least a couple revisions of this device if I'm reading correctly. Could it be that wippersnapper only works on one of them?
Return to “Adafruit IO Wippersnapper Beta”
