Bootloop on Magtag
Bootloop on Magtag
by ceedon on Sun Jul 25, 2021 2:20 pm
After replacing demoboot bin with adafruit-wippersnapper-esp32s2-magtag-1-0-0-beta.3.uf2 from bootloader mode, the first reset results in solid red indictors.
Subsequent resets result in a flash of blue/cyan followed by a reset.
The WIPPER drive appears briefly.
Same process (with proper .uf2) works fine for FunHouse.
The MagTag is the newer version w/ black mask.
https://www.adafruit.com/product/4819
ceedon
Re: Bootloop on Magtag
by brubell on Mon Jul 26, 2021 9:23 am
Did you have the same issue with loading beta.2 (attached)?
adafruit-wippersnapper-esp32s2-magtag-1-0-0-beta+2.uf2
(1.83 MiB) Downloaded 3 times
brubell
by brubell on Mon Jul 26, 2021 9:53 am
Also, which operating system is on your host PC?
brubell
by ceedon on Mon Jul 26, 2021 11:30 am
Win10. Will try loading the other file later today.
ceedon
by ceedon on Mon Jul 26, 2021 6:03 pm
Same behavior in the loop. Green+Blue lights flash -> reset. No solid red first time, though.
ceedon
by brubell on Tue Jul 27, 2021 10:09 am
ceedon wrote:Same behavior in the loop. Green+Blue lights flash -> reset. No solid red first time, though.
What's the output of the 'wippersnapper_boot_out.txt' file on the WIPPER drive?
brubell
by ceedon on Tue Jul 27, 2021 10:39 am
It doesn't stay up long enough to grab it. Any tips to work around that? Can figure out a script if not.
Can try from linux as well. Haven't done so yet.
ceedon
by shamste on Wed Jul 28, 2021 4:07 pm
I'm having the same issues with Beta.2 and Beta.3.
shamste
by scottlnrd on Thu Jul 29, 2021 8:57 pm
I'm having the same issue as well. I'm loading it from a Mac running latest OS.
scottlnrd
by brubell on Fri Jul 30, 2021 9:40 am
shamste wrote:I'm having the same issues with Beta.2 and Beta.3.
Also with MagTag?
brubell
by brubell on Fri Jul 30, 2021 9:41 am
scottlnrd wrote:I'm having the same issue as well. I'm loading it from a Mac running latest OS.
Also with MagTag?
brubell
by scottlnrd on Fri Jul 30, 2021 4:45 pm
Yes, MagTag.
scottlnrd
by scottlnrd on Fri Jul 30, 2021 7:22 pm
I completely erased my MagTag and started from scratch. After I drag the Wippersnapper beta onto the drive and it reboots, the Magtag flashes it's LEDs two blueish colors for several times until it finally stops the cycle, ending in all red LEDs. But never mounts the drive long enough to see anything on it.
scottlnrd
by brubell on Thu Aug 05, 2021 1:56 pm
ceedon wrote:It doesn't stay up long enough to grab it. Any tips to work around that? Can figure out a script if not.
Any luck on Linux?
brubell
by scottlnrd on Fri Aug 06, 2021 12:00 am
I don't think this is an issue of what OS it's running from. It would seem to be a boot loader issue from the wippersnapper uf2 file. There are also at least a couple revisions of this device if I'm reading correctly. Could it be that wippersnapper only works on one of them?
scottlnrd
