boot loop with an updated pyportal (NINA_W102-1.7.4.bin) and beta.5 (1.0.0-beta.5)
load beta.5 and reset
Wipper drive pops up with default secrets and wipper_boot_out.txt
set secrets and reset
purple -> cyan -> +18 seconds -> reboot
no serial output and no drive mounts
If it helps, the state of the pyportal wipper drive after QSPI wipe and beta.5 load is:
secrets.json:
"io_username":"YOUR_IO_USERNAME_HERE",
"io_key":"YOUR_IO_KEY_HERE",
"network_type_wifi_airlift":{
"network_ssid":"YOUR_WIFI_SSID_HERE",
"network_password":"YOUR_WIFI_PASS_HERE"
and
wipper_boot_out.txt:
1.0.0-beta.5
* Successfully added secrets.json and wipper_boot_out.txt to drive!
* ERROR: Default username found in secrets.json, please edit the secrets.json file and reset the board for the changes to take effect
Beta.5 boot loop on pyportal
- brubell
- Learn User Page
Re: Beta.5 boot loop on pyportal
We've had a few reports of beta.5 having issues. I'm looking into this today and have reverted the downloads page to link to the beta.3 firmware for now.
Thank you for your report, it helps us collect data and fix issues.
- brubell
- Learn User Page
UPDATE: Beta.6 has been released and contains a fix for this issue.
If you are still experiencing this issue, please let us know! If you encounter a new issue, please submit a new ticket/forum post and we'll get to it.
- SandPig
beta.6 works great with the LED and Light sensor.
You rock!
You rock!
