beta.7 Metro Airlift - drops offline
by SandPig on Wed Aug 25, 2021 10:19 am
beta.7 (and 6) on the MetroAirlift work fine, but lose connection to Adafruit IO
the device is not rebooting. serial is quiet while it's offline and dashboard commands issued while offline to not get applied once the board returns to an online state. For the brief moment it is online, commands (led blink) work fine.
07:08:43.002 -> Registering Board...
07:08:43.002 -> registerBoard()
07:08:43.002 -> Encoding registration message...Encoded!
07:08:43.002 -> Publishing registration message...Published!
07:08:43.283 -> -> Registration Message
07:08:43.283 -> Found hardware with:
07:08:43.283 -> GPIO Pins: 14
07:08:43.283 -> Analog Pins: 6
07:08:43.283 -> Reference voltage: 3.30v
07:08:43.283 ->
07:08:43.283 -> Successfully checked in, waiting for commands...
07:08:43.283 -> cbSignalTopic: New Msg on Signal Topic
07:08:43.283 -> 15 bytes.
07:08:43.283 -> decodeSignalMsg
07:08:43.283 -> cbSignalMsg
07:08:43.283 -> Sub-messages found: 1
07:08:43.283 -> Signal Msg Tag: Pin Configuration
07:08:43.283 -> cbDecodePinConfigMsg
07:08:43.283 -> configurePinRequest
07:08:43.283 -> Configured digital output pin on D13
07:08:43.283 -> 12 bytes.
07:08:43.318 -> cbSignalMsg
07:08:43.318 -> Sub-messages found: 1
07:08:43.318 -> Signal Msg Tag: Pin Event
07:08:43.318 -> cbDecodePinEventMsg
07:08:43.318 -> Digital Pin Event: Set 13 to 1
07:08:43.387 -> Registered board with Wippersnapper.
07:08:50.672 -> PING!
07:08:58.651 -> PING!
07:09:06.635 -> PING!
07:09:14.333 -> PING!
07:09:21.988 -> PING!
07:09:29.693 -> PING!
07:09:37.678 -> PING!
the board drops offline and immediately the board LED goes solid blue
a few seconds later the led clears and the serial shows the PING and the board is now online and remains connected for 1-2 seconds (at best)
then the blue LED returns for several seconds until it clears and we get another ping
the wipper drive is accessible at all times after initial boot.
I hope this helps, please let me know if you need any other bits of info from me.
SandPig
Re: beta.7 Metro Airlift - drops offline
by jerryn on Wed Aug 25, 2021 11:08 am
FYI -- I had similar issues on Beta.6, but beta.7 has be staying online for me (Metro m4 Airlift). It's been up for several hours now.
jerryn
by SandPig on Thu Aug 26, 2021 8:43 am
inspired by jerryn's success, I fired up my Metro Airlift again to start poking around to see if I could get the same result and now there's no issue.
The board connects right up and there's no more drop between pings.
I don't like magic, but hey, it's working!
I'll update if the magic wears off
SandPig
by brubell on Fri Aug 27, 2021 3:12 pm
Could you please try this with the latest beta.8? Thank you!
brubell
by SandPig on Fri Aug 27, 2021 5:27 pm
after beta.8 load, no disk is mounted and I've got a solid red led - no serial output (no port to monitor)
reload beta.7, no issues
SandPig
by brubell on Mon Aug 30, 2021 10:45 am
SandPig wrote:after beta.8 load, no disk is mounted and I've got a solid red led - no serial output (no port to monitor)
Thank you for reporting, I'll be taking a look at this issue this upcoming week.
brubell
by brubell on Mon Aug 30, 2021 3:04 pm
Could you try updating the UF2 bootloader version, then load Beta.8 onto the AirLift:
https://learn.adafruit.com/adafruit-met ... bootloader
brubell
by SandPig on Tue Aug 31, 2021 1:34 am
UF2 Bootloader v3.3.0-adafruit.10 SFHWRO
Model: Metro M4 AirLift
Board-ID: SAMD51J19A-Metro-AirLift-v0
to:
UF2 Bootloader v3.13.0 SFHWRO
similar result:
beta.7 works, beta.8 does not
Load beta.8 and get a red led
No disk, no port to monitor, nothing
side note, I really appreciate you adding a link for uploading the boot loader - I am very short on time (stupid job) and little things like that really help me.
SandPig
by brubell on Tue Aug 31, 2021 2:14 pm
This is on Windows10?
brubell
by SandPig on Wed Sep 01, 2021 7:47 pm
brubell wrote:This is on Windows10?
MacOS 11.5.2 / MacbookAir M1
SandPig
by brubell on Fri Sep 10, 2021 9:25 am
Is this still occuring with the latest beta.9?
brubell
by SandPig on Sun Sep 12, 2021 5:19 pm
same result from beta.9 - solid red neopixel, no disk, no port to monitor
reload beta.7 - no issue
please let me know if there's anything you want me to poke at
SandPig
by SandPig on Sat Sep 18, 2021 8:42 am
beta.10 is the same, as well
solid red neopixel
SandPig
by brubell on Mon Sep 20, 2021 4:52 pm
Could you try loading the circuitPython 7 UF2 on: https://circuitpython.org/board/metro_m4_airlift_lite/
Then go back to METROBOOT and load WipperSnapper?
brubell
by SandPig on Mon Sep 20, 2021 6:25 pm
brubell wrote:Could you try loading the circuitPython 7 UF2 on: https://circuitpython.org/board/metro_m4_airlift_lite/
loaded CP7
Adafruit CircuitPython 7.0.0 on 2021-09-20; Adafruit Metro M4 Airlift Lite with samd51j19
Board ID:metro_m4_airlift_lite
then reload beta.10
no change - solid red neopixel
SandPig
