Funhouse Beta.9
Funhouse Beta.9
by ksprayberry on Sat Sep 11, 2021 9:49 am
I loaded the beta 9 on my funhouse. I put it really close to our wifi router just to make sure I had the best signal possible. Windows 10 64 bit. It loaded fine, went through the lights, cyan to blue to amber came up in the IO , showed that it had been upgraded to the 9 beta, but disconnected immediately although the amber lights stayed on. Still shows offline and I notice that it seems like it reboots every 5 minutes or so. It's not an immediate reboot loop like the other, but it seems like it takes it a couple minutes and then you see it cycle through the lights again.
ksprayberry
Re: Funhouse Beta.9
by brubell on Mon Sep 13, 2021 4:00 pm
Could you try this again? We've deployed a fix to the WipperSnapper web application. You don't need to update your firmware to a new beta version.
brubell
Re: Funhouse Beta.9
by ksprayberry on Mon Sep 13, 2021 7:16 pm
brubell wrote:Could you try this again? We've deployed a fix to the WipperSnapper web application. You don't need to update your firmware to a new beta version.
I tried it and it still does not show as being online. It also reboots about every 2 minutes.
Kelly
ksprayberry
Re: Funhouse Beta.9
by brubell on Tue Sep 14, 2021 8:42 am
Do you have any components added to the device (on the component page)?
brubell
Re: Funhouse Beta.9
by ksprayberry on Tue Sep 14, 2021 12:44 pm
brubell wrote:Do you have any components added to the device (on the component page)?
No, but I can add one like the LED or something when I get home.
ksprayberry
Re: Funhouse Beta.9
by ksprayberry on Tue Sep 14, 2021 6:24 pm
I just checked, added a compontent and restarted the device and it didn't seem to change it. Looks like it is rebooting and trying to reconnect about every minute.
2021/09/14 6:12:10PM
io-wipper-adafruit-funhouse-esp3
disconnected
2021/09/14 6:12:03PM
connected
2021/09/14 6:11:02PM
disconnected
2021/09/14 6:10:55PM
connected
2021/09/14 6:09:54PM
disconnected
2021/09/14 6:09:47PM
connected
2021/09/14 6:08:45PM
disconnected
2021/09/14 6:08:39PM
connected
2021/09/14 6:07:37PM
disconnected
2021/09/14 6:07:31PM
connected
2021/09/14 6:06:29PM
disconnected
2021/09/14 6:06:22PM
connected
2021/09/14 6:05:20PM
disconnected
2021/09/14 6:05:13PM
connected
2021/09/14 6:04:11PM
disconnected
2021/09/14 6:04:05PM
connected
2021/09/14 6:03:03PM
disconnected
2021/09/14 6:02:56PM
connected
2021/09/14 6:01:55PM
disconnected
2021/09/14 6:01:48PM
connected
2021/09/14 6:00:47PM
disconnected
2021/09/14 6:00:40PM
connected
2021/09/14 5:59:38PM
disconnected
2021/09/14 5:59:32PM
connected
ksprayberry
Re: Funhouse Beta.9
by brubell on Mon Sep 20, 2021 5:07 pm
Where is this output from?
brubell
Re: Funhouse Beta.9
by ksprayberry on Mon Sep 20, 2021 5:51 pm
brubell wrote:Where is this output from?
It's from under Profile/Monitor
ksprayberry
