FUNHOUSE BETA 10
FUNHOUSE BETA 10
by ksprayberry on Mon Sep 20, 2021 6:04 pm
Just saw Beta 10 go up. I just downloaded it and flashed it. Same behavior. Connects, then disconnects. Never shows to be online. I tried using my iphone as a hot spot with it and I tried with our home wifi just trying to rule out maybe it being blocked or something on the home network
ksprayberry
Re: FUNHOUSE BETA 10
by brubell on Tue Sep 21, 2021 9:19 am
Could you:
1) Visit https://www.serialterminal.com
2) Click Connect when the FunHouses' LEDs start blinking, select the FunHouse-S2
3) Copy the serial output from this page, into here.
Thanks, beta.10 exposes verbose debugging and this way ensures you don't need to install Arduino IDE.
brubell
by ksprayberry on Tue Sep 21, 2021 7:08 pm
brubell wrote:Could you:
This is what I get. It just keeps scrolling saying the same thing.
Polling for registration message response...2
ksprayberry
by ksprayberry on Mon Sep 27, 2021 12:15 pm
I downloaded the beta 11 off of Github and the output is basically the same as beta 10. Am I just doing something wrong? I see on here where others are getting information through the serial connection showing MQTT connections being made, etc. and I'm not seeing that. I'll go back and doublecheck my IO key and all, but i'm not seeing the added verbose mentioned. I just don't want to waste your time.
Kelly
ksprayberry
by elaird on Fri Oct 01, 2021 11:53 pm
I came here to try to find my problem also. I have 11 on a Funhouse and it would get to Blue and reboot, so I tried a Magtag and it would connect then disconnect then reconnect then erase the secrets, I fixed the secrets and it would eventually connect. The funhouse finally connected but it could take up to 5 minutes of blue to reboot and blue to reboot to finally connect. The serial terminal said it was trying to connect to io.adafruit.com try 0 (or something) it would do this continuously until it rebooted.
I know it's beta but I am willing to experiment.
elaird
by brubell on Mon Oct 04, 2021 10:14 am
elaird wrote:I came here to try to find my problem also. I have 11 on a Funhouse and it would get to Blue and reboot, so I tried a Magtag and it would connect then disconnect then reconnect then erase the secrets, I fixed the secrets and it would eventually connect. The funhouse finally connected but it could take up to 5 minutes of blue to reboot and blue to reboot to finally connect. The serial terminal said it was trying to connect to io.adafruit.com try 0 (or something) it would do this continuously until it rebooted.
Please check your Adafruit IO credentials. We'll be releasing a new firmware which may address some WiFi bugs people have been having.
brubell
by petitnoel on Mon Oct 04, 2021 12:53 pm
Same here.
1) Do a boot/reset of the Funhouse and restart of the PC (otherwise won't recognize the USB connection).
2) go to WipperSnapper NVM Tool Website and it finds the Funhouse
3) Enter wifi sid and password aio name and password
4) Click on install wippersnapper it loads
5) Last line is reset device to run firmware
6) Do reset and go petitnoel/wippersnapper and nothing shows up.
petitnoel
by brubell on Mon Oct 04, 2021 3:41 pm
petitnoel wrote:Same here.
The NVMTool is only for the ESP32 Feather, the FunHouse runs on the ESP32-S2 platform and has completely different installation instructions.
Please follow the steps listed here: https://learn.adafruit.com/quickstart-a ... esp32-s2-2
If you're still having an issue - please open a new topic in this forum with reproducable steps and we'll take a look
brubell
by petitnoel on Tue Oct 12, 2021 3:17 pm
Works the same with the Adafruit_Webserial_ESPTool.
When I download the TinyUF2 release zip file there is no TINYUF2COMBO.BIN file in the archive.
petitnoel
by petitnoel on Tue Oct 12, 2021 3:52 pm
The file needed for the FunHouse to reload the boot loader is combined.bin not tinyuf2_combo.bin as listed in the learning guide.
petitnoel
by petitnoel on Wed Oct 13, 2021 10:41 am
These should be in the Funhouse Beta 12 topic. Sorry.
petitnoel
cron
