I finally caught the information a little better. It still shows to be offline, but is going through all the lighting steps. Cyan to blue to amber. Then after a while it reboots.
Connecting to: io.adafruit.com
Connect result: 1
MQTT connect packet:
[0x10], d [0x64], [0x00], [0x04], M [0x4D], Q [0x51], T [0x54], T [0x54],
[0x04], [0xC2], [0x00], [0x04], [0x00], ) [0x29], i [0x69], o [0x6F],
- [0x2D], w [0x77], i [0x69], p [0x70], p [0x70], e [0x65], r [0x72], - [0x2D],
a [0x61], d [0x64], a [0x61], f [0x66], r [0x72], u [0x75], i [0x69], t [0x74],
- [0x2D], f [0x66], u [0x75], n [0x6E], h [0x68], o [0x6F], u [0x75], s [0x73],
e [0x65], - [0x2D], e [0x65], s [0x73], p [0x70], 3 [0x33], 2 [0x32], s [0x73],
2 [0x32], 0 [0x30], 8 [0x38], 9 [0x39], 9 [0x39], 0 [0x30], 6 [0x36], [0x00],
[0x0B], k [0x6B], s [0x73], p [0x70], r [0x72], a [0x61], y [0x79], b [0x62],
e [0x65], r [0x72], r [0x72], y [0x79], [0x00], [0x20], d [0x64], f [0x66],
9 [0x39], 4 [0x34], d [0x64], 0 [0x30], f [0x66], 8 [0x38], 1 [0x31], 2 [0x32],
7 [0x37], a [0x61], 4 [0x34], 1 [0x31], 6 [0x36], a [0x61], b [0x62], 7 [0x37],
7 [0x37], d [0x64], 0 [0x30], 6 [0x36], 4 [0x34], 6 [0x36], 6 [0x36], d [0x64],
0 [0x30], a [0x61], c [0x63], 7 [0x37], f [0x66], d [0x64],
Client sendPacket returned: 102
Read data: [0x20],
Packet Type: [0x20],
Read data: [0x02],
Packet Length: 2
Read data: [0x00], [0x00],
MQTT subscription packet:
[0x82], Q [0x51], [0x00], [0x00], [0x00], L [0x4C], k [0x6B], s [0x73],
p [0x70], r [0x72], a [0x61], y [0x79], b [0x62], e [0x65], r [0x72], r [0x72],
y [0x79], / [0x2F], w [0x77], p [0x70], r [0x72], s [0x73], n [0x6E], p [0x70],
r [0x72], / [0x2F], i [0x69], o [0x6F], - [0x2D], w [0x77], i [0x69], p [0x70],
p [0x70], e [0x65], r [0x72], - [0x2D], a [0x61], d [0x64], a [0x61], f [0x66],
r [0x72], u [0x75], i [0x69], t [0x74], - [0x2D], f [0x66], u [0x75], n [0x6E],
h [0x68], o [0x6F], u [0x75], s [0x73], e [0x65], - [0x2D], e [0x65], s [0x73],
p [0x70], 3 [0x33], 2 [0x32], s [0x73], 2 [0x32], 0 [0x30], 8 [0x38], 9 [0x39],
9 [0x39], 0 [0x30], 6 [0x36], / [0x2F], s [0x73], i [0x69], g [0x67], n [0x6E],
a [0x61], l [0x6C], s [0x73], / [0x2F], b [0x62], r [0x72], o [0x6F], k [0x6B],
e [0x65], r [0x72], [0x01],
Client sendPacket returned: 83
[0x82], Q [0x51], [0x00], [0x01], [0x00], L [0x4C], k [0x6B], s [0x73],
Read data: [0x90],
Packet Type: [0x90],
Read data: [0x03],
Packet Length: 3
Read data: [0x00], [0x01], [0x01],
[0x82], U [0x55], [0x00], [0x02], [0x00], P [0x50], k [0x6B], s [0x73],
9 [0x39], 0 [0x30], 6 [0x36], / [0x2F], i [0x69], n [0x6E], f [0x66], o [0x6F],
/ [0x2F], s [0x73], t [0x74], a [0x61], t [0x74], u [0x75], s [0x73], / [0x2F],
b [0x62], r [0x72], o [0x6F], k [0x6B], e [0x65], r [0x72], [0x01],
Client sendPacket returned: 87
Read data: [0x90],
Read data: [0x03],
Packet Length: 3
Read data: [0x00], [0x02], [0x01],
[0x82], [0x17], [0x00], [0x03], [0x00], [0x12], k [0x6B], s [0x73],
y [0x79], / [0x2F], e [0x65], r [0x72], r [0x72], o [0x6F], r [0x72], s [0x73],
[0x00],
Client sendPacket returned: 25
Read data: [0x90],
Read data: [0x03],
Packet Length: 3
Read data: [0x00], [0x03], [0x00],
[0x82], [0x19], [0x00], [0x04], [0x00], [0x14], k [0x6B], s [0x73],
y [0x79], / [0x2F], t [0x74], h [0x68], r [0x72], o [0x6F], t [0x74], t [0x74],
l [0x6C], e [0x65], [0x00],
Client sendPacket returned: 27
Read data: [0x90],
Read data: [0x03],
Packet Length: 3
Read data: [0x00], [0x04], [0x00],
Registering hardware with WipperSnapper...
Registering hardware with IO...
Encoding registration request...Encoding registration msg...MQTT publish packet:
2 [0x32], Q [0x51], [0x00], [0x1F], k [0x6B], s [0x73], p [0x70], r [0x72],
a [0x61], y [0x79], b [0x62], e [0x65], r [0x72], r [0x72], y [0x79], / [0x2F],
w [0x77], p [0x70], r [0x72], s [0x73], n [0x6E], p [0x70], r [0x72], / [0x2F],
i [0x69], n [0x6E], f [0x66], o [0x6F], / [0x2F], s [0x73], t [0x74], a [0x61],
t [0x74], u [0x75], s [0x73], [0x00], [0x05], [0x0A], [0x19], a [0x61],
d [0x64], a [0x61], f [0x66], r [0x72], u [0x75], i [0x69], t [0x74], - [0x2D],
f [0x66], u [0x75], n [0x6E], h [0x68], o [0x6F], u [0x75], s [0x73], e [0x65],
- [0x2D], e [0x65], s [0x73], p [0x70], 3 [0x33], 2 [0x32], s [0x73], 2 [0x32],
[0x10], [0xB2], [0xBE], [0x05], z [0x7A], [0x0D], 1 [0x31], . [0x2E],
0 [0x30], . [0x2E], 0 [0x30], - [0x2D], b [0x62], e [0x65], t [0x74], a [0x61],
. [0x2E], 1 [0x31], 2 [0x32],
Publishing across: ksprayberry/wprsnpr/info/status
Read data: @ [0x40],
Packet Type: @ [0x40],
Read data: [0x02],
Packet Length: 2
Read data: [0x00], [0x05],
Publish QOS1+ reply: @ [0x40], [0x02], [0x00], [0x05],
Published!
Polling for registration message response...2
FUNHOUSE BETA 12
- petitnoel
Re: FUNHOUSE BETA 12
Here are the steps I used to reinstall the FunHouse UF2 and connect to io.adafruit.com. From https://learn.adafruit.com/adafruit-fun ... bootloader (with corrections):
1) Reboot your PC so it will recognize the USB port
2) in adafruit.com download tinyuf2-adafruit_funhouse_esp32s2-0.5.2
3) unzip the above into a folder
4) on funhouse hold down BOOT and click RESET
5) open https://adafruit.github.io/Adafruit_WebSerial_ESPTool
6) Connect it to the serial port shown in device manager for the ESP32
7) Erase the flash
8) Select the unzipped file combined.bin from 3 above
9) Program the flash (still in the WebSerial_ESPTool)
10) Now you should see HOUSEBOOT as a file system on your computer
11) Download wippersnapper.funhouse_tinyusb.1.0.0-beta.12 from github
12) Drag the file from 11 to HOUSEBOOT. Now the directory is called WIPPER
13) Edit secrets configuration file with io and wifi info
14) go to io.adafruit.com/<yourname>/dashboards/ and click on wippersnapper on the top
15) you should now see the funhouse device listed as Adafruit Funhouse ESP32-2
16) click on it and you should be able to add the PIR and button components.
7) Erase the flash
- brubell
- Learn User Page
^ I'm curious if this works for you kspayberry, please let me know.
- ksprayberry
Brent
I plan on trying it as soon as I get home tomorrow. I tried something similar, but I think I need to follow this step by step. I can’t help but think it’s something I’m doing wrong. PEBKAC problem exists between keyboard and chair.
- ksprayberry
Brentbrubell wrote:^ I'm curious if this works for you kspayberry, please let me know.
I tried and I could not get this to work. Maybe I missed a critical step or something in this process, but it didn't work either. I did however have good success with an esp32 Huzzah last night. I was able to program it and use it with my credentials and It came up and showed to be online right away. I even ran the led routine and it seemed to work well. I wonder if there is something wrong with my funhouse board?
Kelly
- brubell
- Learn User Page
You're connecting to the same 2.4GHz network with both the FunHouse and the ESP32Huzzah?
- ksprayberry
Yes, using the same network for both. I can't help but think something isn't quite right with the funhouse now. I tried to load the dragon eye thing last night. I tried to load the spooky dragon eye.uf2 last night and it didn't seem to work, so I loaded the circuit python over and it seemed to take, but when I resent it with the double click and try to load the dragon eye, it just copied it to the USB. maybe I'll try erasing it again and starting over.brubell wrote:You're connecting to the same 2.4GHz network with both the FunHouse and the ESP32Huzzah?
thanks
kelly
