Feather HUZZAH ESP32 Installs old firmware
by adafruitguy on Sun Oct 17, 2021 9:00 pm
A fresh Wippersnapper install on a Feather HUZZAH ESP32 installs v1.0.0-beta.12 (not .13) and remains "Offline"...
Fresh Install via WebSerial_NVMGenerator
Screen Shot 2021-10-17 at 8.53.24 PM.png (219.2 KiB) Viewed 361 times
Offline
Screen Shot 2021-10-17 at 8.53.40 PM.png (186.23 KiB) Viewed 361 times
adafruitguy
Re: Feather HUZZAH ESP32 Installs old firmware
by brubell on Mon Oct 18, 2021 9:50 am
The NVMTool should be updated to beta.13 now, I just pulled in the new binary (https://github.com/adafruit/Adafruit_We ... or/pull/13)
brubell
by adafruitguy on Mon Oct 18, 2021 4:05 pm
Was able to pick-up bata.14, thank you!
Still not able to get the Feather Huzzah to come online. Clearly it's initially connecting to Adafruit IO as it's reporting with v1.0.0-beta.14.
Stubborn Feather Huzzah
Screen Shot 2021-10-18 at 4.01.34 PM.png (611.7 KiB) Viewed 335 times
adafruitguy
by adafruitguy on Tue Oct 19, 2021 4:38 pm
Here's the logging from the Feather Huzzah 32...
11:53:08.418 ->
11:53:08.418 -> rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
11:53:08.418 -> configsip: 0, SPIWP:0xee
11:53:08.418 -> clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
11:53:08.418 -> mode:DIO, clock div:1
11:53:08.418 -> load:0x3fff0030,len:1252
11:53:08.418 -> load:0x40078000,len:12732
11:53:08.455 -> load:0x40080400,len:3100
11:53:08.455 -> entry 0x400805ec
11:53:08.784 -> Subscribing to MQTT topics...
11:53:08.784 -> Added sub 0
11:53:08.784 -> Added sub 1
11:53:08.784 -> Added sub 2
11:53:08.822 -> Added sub 3
11:53:08.822 -> Added sub 4
11:53:11.602 -> Connecting to: io.adafruit.com
11:53:12.947 -> Connect result: 1
11:53:12.947 -> MQTT connect packet:
11:53:12.947 ->      [i]REDACTED DECODE[/i]
11:53:13.020 -> Client sendPacket returned: 95
11:53:13.057 -> Read data:        [0x20],
11:53:13.057 -> Packet Type:        [0x20],
11:53:13.057 -> Read data:        [0x02],
11:53:13.057 -> Packet Length:   2
11:53:13.057 -> Read data:        [0x00],   [0x00],
11:53:13.057 -> MQTT subscription packet:
11:53:13.057 ->      [i] REDACTED DECODE[/i]
11:53:13.131 -> Client sendPacket returned: 76
11:53:13.646 -> MQTT subscription packet:
11:53:13.646 ->      [i]REDACTED DECODE[/i]
11:53:13.718 -> Client sendPacket returned: 76
11:53:13.756 -> Read data:        [0x90],
11:53:13.756 -> Packet Type:        [0x90],
11:53:13.756 -> Read data:        [0x03],
11:53:13.756 -> Packet Length:   3
11:53:13.756 -> Read data:        [0x00],   [0x01],   [0x01],
11:53:13.792 -> MQTT subscription packet:
11:53:13.792 ->      [i]REDACTED DECODE[/i]
11:53:13.829 -> Client sendPacket returned: 80
11:53:13.902 -> Read data:        [0x90],
11:53:13.902 -> Packet Type:        [0x90],
11:53:13.902 -> Read data:        [0x03],
11:53:13.902 -> Packet Length:   3
11:53:13.902 -> Read data:        [0x00],   [0x02],   [0x01],
11:53:13.902 -> MQTT subscription packet:
11:53:13.902 ->       [i]REDACTED DECODE[/i]
11:53:13.976 -> Client sendPacket returned: 80
11:53:14.009 -> Read data:        [0x90],
11:53:14.009 -> Packet Type:        [0x90],
11:53:14.009 -> Read data:        [0x03],
11:53:14.009 -> Packet Length:   3
11:53:14.009 -> Read data:        [0x00],   [0x03],   [0x01],
11:53:14.009 -> MQTT subscription packet:
11:53:14.009 ->       [i]REDACTED DECODE[/i]
11:53:14.045 ->      [0x00],
11:53:14.045 -> Client sendPacket returned: 25
11:53:14.081 -> Read data:        [0x90],
11:53:14.081 -> Packet Type:        [0x90],
11:53:14.081 -> Read data:        [0x03],
11:53:14.081 -> Packet Length:   3
11:53:14.081 -> Read data:        [0x00],   [0x04],   [0x00],
11:53:14.081 -> MQTT subscription packet:
11:53:14.081 ->       [i]REDACTED DECODE[/i]
11:53:14.118 -> Client sendPacket returned: 27
11:53:14.156 -> Read data:        [0x90],
11:53:14.156 -> Packet Type:        [0x90],
11:53:14.156 -> Read data:        [0x03],
11:53:14.156 -> Packet Length:   3
11:53:14.156 -> Read data:        [0x00],   [0x05],   [0x00],
11:53:14.156 -> Registering hardware with WipperSnapper...
11:53:14.156 -> Registering hardware with IO...
11:53:14.156 -> Encoding registration request...Encoding registration msg...MQTT publish packet:
11:53:14.192 ->      [i] REDACTED DECODE[/i]
11:53:14.228 -> Client sendPacket returned: 75
11:53:14.265 -> Publishing across:        [i] REDACTED DIRECTORY[/i]
11:53:14.302 -> Read data:      @ [0x40],
11:53:14.302 -> Packet Type:      @ [0x40],
11:53:14.302 -> Read data:        [0x02],
11:53:14.302 -> Packet Length:   2
11:53:14.302 -> Read data:        [0x00],   [0x06],
11:53:14.302 -> Publish QOS1+ reply:      @ [0x40],   [0x02],   [0x00],   [0x06],
11:53:14.302 -> Published!
11:53:14.302 -> Polling for registration message response...2
11:53:14.338 -> Polling for registration message response...2
11:53:14.376 -> Polling for registration message response...2
11:53:14.412 -> Polling for registration message response...2
11:53:14.448 -> Polling for registration message response...2
11:53:14.483 -> Polling for registration message response...2
11:53:14.520 -> Polling for registration message response...2
11:53:14.555 -> Polling for registration message response...2
11:53:14.592 -> Polling for registration message response...2
11:53:14.630 -> Polling for registration message response...2
adafruitguy
by brubell on Wed Oct 20, 2021 11:46 am
Thanks for the serial output, I was just going to ask for that. Could you submit the error log to http://io.adafruit.com/support without redacted information? I need that information in order to dive into this bug. It will only go to the inbox of the IO team.
Thank you.
brubell
by adafruitguy on Wed Oct 20, 2021 1:30 pm
I will send that now.
Hopefully it's coming through, I'm just getting a blank page when I hit submit.
adafruitguy
by brubell on Mon Nov 01, 2021 9:54 am
Are you attempting to connect to a 5GHz network?
brubell
by adafruitguy on Tue Nov 02, 2021 4:33 am
My network supports 802.11a/b/g/n/ac/ax (2.4GHz as well as 5GHz Lo & Hi). The HUZZAH32 is spec’ed @ 802.11b/g/n which makes it a 2.4GHz device, and that’s where my network is seeing it show up…
HUZZAH32 Connected via 2.4GHz
I have a Metro M4 w/ Airlift & PyPortal Titano both running WipperSnapper which also have an ESP32 successfully connected via 2.4GHz to the same network. My ESP32-S2 WipperSnapper devices (Funhouse, MagTag, and Metro ESP32-S2) are also connected via the 2.4GHz band to the same network.
adafruitguy
by brubell on Fri Nov 05, 2021 10:19 am
I'm going to look into that serial log when work on I2C ramps down, and get back to you. I'm gathering data for this specific registration error, as I've seen it a few times but am unable to locally reproduce it so far.
brubell
by adafruitguy on Tue Nov 09, 2021 9:04 am
I successfully installed WipperSnapper on second HUZZAH ESP32...
Two HUZZAH32's
Screen Shot 2021-11-09 at 7.51.32 AM.png (765.01 KiB) Viewed 222 times
The working HUZZAH32 (pink Micro-B cable, on the right) happens to have different (simpler) markings on the chip packaging...
Different Packaging
And the working HUZZAH32 board has "1617" in a 7-segment font on the back, and additional markings under the "32"...
HUZZAH32 Backside
Screen Shot 2021-11-09 at 7.59.14 AM.jpeg (288.32 KiB) Viewed 222 times
Code load, and everything else was the same.
Possibly Rev 0 vs Rev 1 of the ESP32 silicon?
adafruitguy
by brubell on Mon Nov 15, 2021 11:48 am
Oh, this is indeed strange, thanks for investigating. I'm using a much older Adafruit Feather ESP32.
Could you connect both feathers to the Adafruit ESPWebtool, https://adafruit.github.io/Adafruit_WebSerial_ESPTool. Then, copy and paste the data it outputs here. That'll let me look at differences between the modules.
brubell
by adafruitguy on Thu Nov 18, 2021 3:54 pm
Both have been updated to Beta.15
Beta 15
Screen Shot 2021-11-18 at 2.47.17 PM.png (212.93 KiB) Viewed 190 times
Same behavior unit one initially connects, shares it's version number and stays "offline", the second unit... No problem.
Output from "Adafruit_WebSerial_ESPTool", as requested, (not NVMGenerator)...
Unit 1:
Adafruit WebSerial ESPTool loaded.
Connecting...
Connected successfully.
Try to reset.
Timed out after 100 milliseconds
Connected to ESP32
MAC Address: 30:AE:A4:14:0B:00
Uploading stub...
Running stub...
Stub is now running...
WARNING: ESP32 is having issues working at speeds faster than 115200. Continuing at 115200 for now...
Unit 2:
Connecting...
Try to reset.
Connected to ESP32
MAC Address: 24:0A:C4:00:16:3E
Uploading stub...
Running stub...
adafruitguy
