On Saturday, August 13, 2022 we will be working on the Adafruit Customer Support Forums. If you visit over the weekend and things are not complete yet, please check back later, https://adafruit.com/forumupdates
Unresponsive Funhouse after Wippersnapper Install
by benczech212 on Wed Nov 24, 2021 5:39 pm
I recently attempted to use the WhipperSnapper platform on my Adafruit Funhouse. I followed this guide: https://learn.adafruit.com/quickstart-adafruit-io-wippersnapper/welcome-to-wippersnapper but now my board is unresponsive. It does not reset when I press the reset button, nor when I hold BOOT and press reset. I cannot see the device in Windows as a storage device or as a COM device, nor can Chrome see the device when I attempt to connect.
Suggestions?
benczech212
Re: Unresponsive Funhouse after Wippersnapper Install
by mikeysklar on Fri Nov 26, 2021 4:40 pm
When you unplug the Funhouse and plug it back in then use the sequence to get into ROM bootloader does that help?
To enter ROM bootloader mode, hold down DFU button while clicking reset button mentioned above.
Does any COM port show up on Windows even if the mounted device does not appear?
mikeysklar
by benczech212 on Mon Nov 29, 2021 1:10 pm
Progress,
I unplugged the device, plugged it in (nothing detected), then healed down the BOOT button and pressed RESET with BOOT still down. I don't see a storage device, but I do see it as a COM device now. How should I proceed?
benczech212
by mikeysklar on Mon Nov 29, 2021 7:01 pm
Good enough. All we need is a COM port. It sounds as though the bootloader is stuck on your Funhouse so you will need to reload it. It is a four step process that is well documented here.
https://learn.adafruit.com/adafruit-fun ... bootloader
mikeysklar
