Could you try the following steps before we troubleshoot further?
1) Reboot your PC.
2) Download the bootloader (Download the tinyuf2 combined.bin file) from:
https://learn.adafruit.com/adafruit-esp ... -3089838-63) unzip the above into a folder
4) on the ESP32-S2 feather, hold down BOOT and click RESET
5) open
https://adafruit.github.io/Adafruit_WebSerial_ESPTool6) Connect it to the serial port shown in device manager for the ESP32-S2
7) Erase the flash
8) Select the unzipped file combined.bin from step 3 above
9) Program the flash (still in the WebSerial_ESPTool)
10) Now you should see FEATHERBOOT as a file system on your computer
11) Download the WipperSnapper UF2 from github
12) Drag the file from 11 to METROBOOT. Now the directory is called WIPPER
13) Edit secrets configuration file with io and wifi info
14) Go to io.adafruit.com/<yourname>/dashboards/ and click on wippersnapper on the top
15) You should now see the funhouse device listed as Feather ESP32-S2
