S2 Boards Going Offline Since Beta.19
Since upgrading from Beta.16 to Beta.19 my S2 boards are going offline, and require a reboot to reconnect.
They are available via ping on the local networks, but no longer connected to IO. This includes: FunHouse, MagTag, Metro S2, Adafruit Feather S2, and QT Py S2.
My Ultimate Maker Feather S2 is still running Beta.16 and hasn't experienced a problem. Metro M4 w/ AirLift & PyPortal do not have the disconnect problem and are running Beta.19.
Huzzah 32's are covered in a separate issue.
Re: S2 Boards Going Offline Since Beta.19
Serial output from Adafruit Feather S2...
MQTT ping packet:
[0xC0], [0x00],
Client sendPacket returned: 2
Read data: [0xD0],
Packet Type: [0xD0],
Read data: [0x00],
Packet Length: 0
PING!
MQTT ping packet:
[0xC0], [0x00],
Read data: [0xD0],
Read data: [0x00],
Packet Length: 0
PING!
MQTT ping packet:
[0xC0], [0x00],
Read data: [0xD0],
Read data: [0x00],
Packet Length: 0
PING!
MQTT ping packet:
[0xC0], [0x00],
Connecting to: io.adafruit.com
Connect result: 0
Connect result: 0
Connect result: 0
Connect result: 0
Connect result: 0
Connect result: 0
Connect result: 0
Connect result: 0
Connect result: 0
Connect result: 0
Connect result: 0
ERROR: Unable to connect to Adafruit.IO
Reverting the S2 boards to beta.16 fixes the problem.
- brubell
Do you have the full serial output after a reboot/reset? It should include information prior to the output you submitted?
Issue filed here for tracking: https://github.com/adafruit/Adafruit_Wi ... issues/199
Except for the initial stuff @ boot it's many minutes to a few hours of the MQTT ping packets.
Are you looking for stuff near the board starting or something else?
MQTT ping packet:
[0xC0], [0x00],
Read data: [0xD0],
Read data: [0x00],
Packet Length: 0
PING!
- brubell
Near the board starting.Are you looking for stuff near the board starting or something else?
To confirm - the boards are initially connected, then disconnect at some point, then fail to reconnect? Or are they not connecting at all
I can happily send the board bring-up stuff. It includes my IO Key - so let me know where to send it, or if you want that redacted out.
The ESP32-S2 boards all connect on Beta.19 and stay connected for a little while. Which I would define as a random # of minutes or hours, then they all eventually get to the "ERROR: Unable to connect to Adafruit.IO" state - while remaining locally responsive to pings (IP ICMP).
The SAMD51 + AirLift boards keep chugging without a problem on Beta.19, as do my ESP32-S2 boards on Beta.16. Both have been connected since board boot (for week+ / weeks).
We are tracking the HUZZAH ESP32 on Beta 19 in a separate thread. That never connected to Adafruit.IO with Beta.19. And, in yet another thread, I have one HUZZAH ESP32 unit that never once connected to Adafruit IO.
- brubell
Submit those logs to io.adafruit.com/support and the logs will be emailed to us, privately.
Thanks for the explanation regarding the behavior of the boards, looking into both issues this week.
- Jdfry
Has there been any resolution on this yet? I have a PyPortal that is behaving the same way, in that from a few minutes to several hours (~18+) the board will disconnect from Adafruit.IO. I'm running CircuitPython and have modified the code with additional timeout time of 5 seconds via io.loop(5) in the try statement, with an except statement of wifi.reset(), wifi.connect(), and another indented try with io.reconnect() and except statement of io.connect(). I thought I had solved the issue by including wifi.connect() after the example code's wifi.reset(), but then still crashed after about 18 hours.
- brubell
This thread is for Adafruit WipperSnapper, please post a CircuitPython issue in the Adafruit IO Forum (viewforum.php?f=56) along with your full code so we can take a look at it.Jdfry wrote:Has there been any resolution on this yet? I have a PyPortal that is behaving the same way, in that from a few minutes to several hours (~18+) the board will disconnect from Adafruit.IO. I'm running CircuitPython and have modified the code with additional timeout time of 5 seconds via io.loop(5) in the try statement, with an except statement of wifi.reset(), wifi.connect(), and another indented try with io.reconnect() and except statement of io.connect(). I thought I had solved the issue by including wifi.connect() after the example code's wifi.reset(), but then still crashed after about 18 hours.
