Metro M4 Airlift Lite beta.21 wants ESP Module Firmware Upgr
by adafruitguy on Thu Jan 06, 2022 6:16 pm
After upgrading my Metro M4 Airlift Lite from beta.20 to beta.21, I am getting the following error, and continuous board reboot...
[Disconnected]
[Connected]
Subscribing to MQTT topics...
Added sub 0
Added sub 1
Added sub 2
Added sub 3
Added sub 4
Attempting to connect to WiFi...
Please upgrade the firmware on the ESP module to the latest version.
[Disconnected]
[Connected]
Added sub 0
Added sub 1
Added sub 2
Added sub 3
Added sub 4
adafruitguy
Re: Metro M4 Airlift Lite beta.21 wants ESP Module Firmware
by brubell on Fri Jan 07, 2022 11:19 am
brubell
by brubell on Fri Jan 07, 2022 4:45 pm
I'm unable to reproduce the esp module firmware upgrade error on my Metro M4 AirLift Lite. Please try following the steps on this page to upgrade your ESP32 AirLift's firmware: https://learn.adafruit.com/upgrading-es ... -one-board and reinstall beta 21.
However, I am able to get the continuous board reboot (proposed patch is here: https://github.com/adafruit/Adafruit_Wi ... o/pull/205).
I've included a build UF2 from that pull request, could you confirm it works on your end as well?
wippersnapper.metro_s2_tinyusb.1.0.0-beta.21-4-g3fa3371.uf2
(1.67 MiB) Downloaded 5 times
brubell
by adafruitguy on Fri Jan 07, 2022 5:37 pm
That build gives a quick warning on firmware, boots, and connects successfully.
It is still claiming: 1.0.0-beta.20 in wipper_boot_out.txt ???
I will proceed through the passthrough / upgrade procedure.
Boot, firmware notice, success....
[Connected]
Added sub 0
Added sub 1
Added sub 2
Added sub 3
Added sub 4
Connecting to: io.adafruit.com
Connect result: 1
MQTT connect packet:
[Lot's of stuff to REDACT]
[Success and lots of happy MQTT ping packets]
adafruitguy
by adafruitguy on Fri Jan 07, 2022 9:31 pm
Is that image the Metro M4 w/ AirLift or Metro S2?
I am 99% sure I was still running the beta.20 before the ESP AirLift firmware update. It never said it was running anything other than beta.20.
After the ESP module firmware upgrade...
- The pull build keeps reloading as METROM4BOOT only.
- beta.21 no longer shows the ESP firmware version warning, but keeps restarting.
- and, beta.20 still seems reliable, and no longer warnings on the ESP firmware version.
adafruitguy
by brubell on Mon Jan 10, 2022 1:03 pm
Oops, linked the wrong one..
If you go to... https://github.com/adafruit/Adafruit_Wi ... 1669203746 -> click "build-files" -> download zip -> `metro_m4...airliftlite.uf2` should be in there.
It should display on IO as beta.22.
brubell
by adafruitguy on Mon Jan 10, 2022 1:47 pm
Got it - thank you.
Up & running, on the Metro M4 w/ AirLift. So far it's doing much better than .21.
Got beta.22 on M4 Metro
Screen Shot 2022-01-10 at 12.38.58 PM.png (202.26 KiB) Viewed 48 times
My PyPortal was having similar issues. Complaining on ESP firmware & frequent reboots. I've upgraded the ESP firmware, and will try out .22 on it as well.
adafruitguy
