WipperSnapper and Adafruit AHT20
- bcarlson
I've had an Adafruit ESP32-S2 Feather running WipperSnapper v1.0.0-beta.22 with an Adafruit AHT20 connect, to log temperature and humidity, it ran fine for a couple of weeks and then stopped uploading temperature and humidity updates, the ESP32-S2 Feather remained online. To troubleshoot I have removed the AHT20 component from the WipperSnapper board and removed the ESP32-S2 Feather as a WipperSnapper device and started all over adding the ESP32-S2 Feather back as a WipperSnapper device, the device showed online I then adding the AHT20 component. I then started the I2C scan, the scan completed and found address 0x38, with the temperature sensor and humidity sensor enabled I created the component. I got a green light on the AHT20 board and waited for over an hour and I still do not get temperature or humidity updates.
- michimac
Re: WipperSnapper and Adafruit AHT20
Glad to hear I am not alone. Identical issue. I loaded the arduino example code for the ADT20 and confirmed I was getting a reading from both temperature and humidity. Everything shows up as described on Wippersnapper, but no data.
- michimac
https://www.adafruitstatus.com/ shows Error 525
- brubell
- Learn User Page
What were the periods your sensors were set to? Every 15 minutes? Could you try setting them to "Every 30 seconds"?michimac wrote:Glad to hear I am not alone. Identical issue. I loaded the arduino example code for the ADT20 and confirmed I was getting a reading from both temperature and humidity. Everything shows up as described on Wippersnapper, but no data.
- michimac
Done. Feather shows online. No data from sensor.
- redbishop
Same issue on my end with the same hardware and firmware.
- michimac
Pretty sure it ain't us...
- michimac
Now the server status seems fixed, but still no data.
- redbishop
Yes, same here. Device is still listed as online but No Data Yet.
- nagrom78
Same here no data showing up in my feed.
- brubell
- Learn User Page
redbishop wrote:Yes, same here. Device is still listed as online but No Data Yet.
nagrom78 wrote:Same here no data showing up in my feed.
Hi, this was a mistake on our end as we're working on adding more I2C sensors this week. It should be fixed now.michimac wrote:Now the server status seems fixed, but still no data.
If you're still experiencing issues, please try deleting the sensor component and re-initializing it.
Thank you for reporting the issue and please let us know if it's working again for you.
- michimac
Bingo. The data is flowing. Thank you!
- redbishop
Ok for me as well. Thanks for fixing.
How do we find out when new I2C devices are available in WipperSnapper?
- brubell
- Learn User Page
We'll blog when a new sensor is released - https://blog.adafruit.com/?s=wippersnapperHow do we find out when new I2C devices are available in WipperSnapper?
