Beta.23 intermittent connection errors & firmware reboots
by adafruitguy on Sun Feb 06, 2022 1:20 pm
With Beta.23 I am seeing intermittent WipperSnapper connection errors & firmware reboots, on the following...
    Adafruit QT Py ESP32-S2
    Adafruit ESP32-S2 Feather
    Adafruit ESP32-S2 TFT Feather
    Adafruit Funhouse ESP32-S2
Here's an example just before from the ESP32-S2 Feather...
Read data:              @ [0x40],
Packet Type:            @ [0x40],
Read data:                [0x02],
Packet Length:  2
Read data:                [0x00],   [0x84],
Publish QOS1+ reply:            @ [0x40],   [0x02],   [0x00],   [0x84],
PUBLISHED!
PING!
MQTT ping packet:
          [0xC0],   [0x00],
Client sendPacket returned: 2
Read data:                [0xD0],
Packet Type:              [0xD0],
Read data:                [0x00],
Packet Length:  0
PING!
MQTT ping packet:
          [0xC0],   [0x00],
FSM_NET_ESTABLISH_MQTT
Connecting to: io.adafruit.com
Connect result: 0
Unable to connect to Adafruit IO MQTT, retrying in 5 seconds...
Connect result: 0
Connect result: 0
Connect result: 0
Connect result: 0
ERROR [WDT RESET]: ERROR: Unable to connect to Adafruit.IO MQTT, rebooting soon...
I'm happy to email longer logs, if it's helpful.
My WipperSnapper M4's with Airlift and Huzzah32 appear to not have this issue.
adafruitguy
Re: Beta.23 intermittent connection errors & firmware reboot
by brubell on Mon Feb 07, 2022 12:15 pm
Are the connection errors only happening after a successful connection is established?
On io.adafruit.com/monitor, do you see any errors occurring?
brubell
by adafruitguy on Mon Feb 07, 2022 5:03 pm
None.
No Errors
Screen Shot 2022-02-07 at 3.56.36 PM.png (17.47 KiB) Viewed 37 times
adafruitguy
