Beta 30 Funhouse Not Connecting
by rsbohn on Tue Apr 12, 2022 1:52 pm
Installed wippersnapper Beta 30 on my new Funhouse board. The device shows up as a new device on the web site, but it never shows up as "Online".
I have the correct entries in secrets.json.
The on-board LEDs go from purple to blue to yellow, stay yellow a long time. then the board resets.
Partial debug log:
Publishing across: rsbohn/wprsnpr/info/status
Read data: @ [0x40],
Packet Type: @ [0x40],
Read data: [0x02],
Packet Length: 2
Read data: [0x00], [0x06],
Publish QOS1+ reply: @ [0x40], [0x02], [0x00], [0x06],
Published!
Polling for registration message response...2
Polling for registration message response...2 ... (repeats until reboot)
rsbohn
Re: Beta 30 Funhouse Not Connecting
by brubell on Fri Apr 15, 2022 9:58 am
I'm unable to replicate this on my end.
Could you try deleting the device from your WipperSnapper account, and trying again?
brubell
by rsbohn on Thu Apr 21, 2022 12:39 pm
Installed the -beta.31 firmware on the funhouse, same behavior.
I put the Huzzah -beta.31 firmware on a ESP-WROOM-32 dev board and it connects no problem.
rsbohn
by brubell on Wed Jun 08, 2022 2:18 pm
This is an old topic, but I wanted to give an update as I've finally been able to spot and reproduce this bug from my end.
Details of what occurred are here on this pull request: https://github.com/adafruit/Adafruit_Wi ... o/pull/268
The issue has been fixed in Beta.36 This issue should be fixed going forwards: https://github.com/adafruit/Adafruit_Wi ... .0-beta.36
brubell
