๐Ÿ“ฃ๐Ÿ“ช ๐Ÿšš Adafruit will not be shipping USPS orders Monday January 20, 2020 ๐Ÿ—“. Expedited USPS orders placed after 11am ET ๐Ÿ•š Friday January 17 will go out Tuesday January 21 ๐Ÿ“ฃ๐Ÿ“ช๐Ÿšš
x0xb0x not responding to MIDI
by midiquestions on Mon Dec 25, 2017 6:35 pm
Hi, I recently rewired my studio and discovered that my x0xb0x is not responding to MIDI for some reason, either in note-play mode (on any channel) or in MIDI-sync pattern mode. The cables and the port itself seem to be fine as the THRU function is working to pass notes, so apparently it is receiving MIDI OK at the IN port, but for some reason, these are not reaching the x0x's brain. Any ideas on what is going on and how to fix it?
midiquestions
Re: x0xb0x not responding to MIDI
by TeeDogg on Sun Jan 28, 2018 11:00 pm
Any luck getting a response with this? Have you figured it out? I'm having the same problem with a X0xi0 I just got.
TeeDogg
by midiquestions on Tue Jan 30, 2018 12:13 am
Yes, antto suggested I check continuity on J3, which passes along the MIDI signals internally. Sure enough, I touched up the solder points on both ends of the cable, it now it's responding to MIDI notes and sequence-start commands again.
midiquestions
