xoxbox problem ableton
x0x0x0x0x0x
lorenaustin
Post by lorenaustin »
I've set my xoxbox in midi play mode. everything works fine and plays in sync with my beats, but it's like the sound comes out of the midi track(??) and not from my audio track I've created (ext in). Also when I adjust the master of ableton the xoxbox stays at the same volume. So I have to adjust the volume on the xoxbox. I've tried everything I think but nothing seems to help. It's like my midi channel is monitoring or something.
Thanks in advance!
antto
Re: xoxbox problem ableton
Post by antto »
this is not a x0xb0x issue really
i'm not familiar with your DAW, but it sounds to me like you are hearing the x0xb0x via your soundcard's "monitoring" feature.. that means directly, outside of the DAW
in my case (with an m-audio card) there's a fancy control panel where you can mute the inputs for monitoring, then you won't hear the x0xb0x unless you enable the audio-in thru your DAW (with asio in my case)
Return to “General x0xing”
