output
by filq on Thu May 19, 2011 3:35 pm
hello
should i use phone or mix out for the output of x0xb0x?
phones out is cool for the headphones, but it seems too noisy for me
mix out is not noisy, but i can't check it with my soundcard input as the card broken now
thanks
filq
Re: output
by antto on Thu May 19, 2011 5:34 pm
in my experience, they are both fine
only that mix-out is mono (or is it my damn cables, who knows..)
antto
Re: output
by altitude on Sat May 21, 2011 2:39 pm
The mix out, the phones level is for headphones, not line level.
altitude
Re: output
by yellesmakt on Thu Sep 07, 2017 11:33 pm
is the MIX OUT 1/4 TRS or 1/4 TS?
yellesmakt
Re: output
by yellesmakt on Fri Sep 08, 2017 12:15 am
I just read in another thread that it seems to be TS. I verified with a TS cable that it's significantly louder in my mixer using a TS cable over a TRS cable. Can this go into the manual?
yellesmakt
Re: output
by Nordcore on Fri Sep 08, 2017 3:47 am
Due to a questionable design decision the ring of the TRS MIX output jack is left open.
So if you connect it with a TRS cable to a mixer with an symmetrical input, the "cold" part of input is open. Which works bad.
Solder a wire from ring to ground on the I/O board and the problem is gone.
(In a good design the "cold" (ring) gets the same output impedance as the "hot" (tip), such outputs are called pseudo symmetrical. They work perfectly together with all other studio gear. )
Nordcore
Re: output
by yellesmakt on Sat Sep 09, 2017 12:37 pm
OK, thank you!
yellesmakt
