📣📪 🚚 Adafruit will not be shipping USPS orders Monday January 20, 2020 🗓. Expedited USPS orders placed after 11am ET 🕚 Friday January 17 will go out Tuesday January 21 📣📪🚚
MarOS midi problems
MarOS midi problems
by rasseru on Thu Sep 12, 2013 2:55 pm
Hi guys. one step away from acid heaven -
I cant get any sort of midi in to work.
ive got marOS 1.4.1 installed, i love it - its brilliant. I can send out a midi sync, but i cant get a midi in to work properly - and i dont understand the midi modes.
could someone walk me through them a bit? ive tried midi play - no notes produce anything. ive tried midi patterns, nothing. tried every channel... ableton recieves on channel 3, notes ok, but as for triggering patterns back again.... nada
i dont understand how to change out of classic mode or what could be the problem.. any ideas?
thanks
rasseru
Re: MarOS midi problems
by antto on Fri Sep 13, 2013 5:40 am
perhaps try to contact Mario
antto
by rasseru on Mon Feb 17, 2014 4:42 pm
i cant PM him for some reason.??
i have some time off work and im trying again and I cant get it to work - tried pressing d# or f# or whatever it says in the manual to change to classic mode. not working... ended up buying a syncgen for a lot fo money because I thought the MIDI might be faulty so DINsync would work, and nothing!!!!
it was made by Brian castro so it should work fine... any ideas anyone?>?????
it would really help!
rasseru
by antto on Mon Feb 17, 2014 5:41 pm
i have no idea about marOS
do you have a link to the manual?
PM's were disabled on the whole adafruit forum since.. uhm.. a few years.. due to spam
and they're still not enabled
antto
by rasseru on Tue Feb 18, 2014 5:31 am
its SOKKOS except for this:
1. MIDI Sync Mode
By default, the xoxbox is in “classic-mode” - it starts playing when receiving a MIDI -start command. If
you want to use the new MIDI-Sync mode the way it is meant (in a MIDI DAW environment), you should
turn that mode off by pressing F#1 (Start-Mode-Key). Pressing it again, brings it back to classic mode. The
description following relates to the box being not in classic-mode. The current mode is stored and
restored after the machine was turned off.
Normal Start/Stop Mode
Unlike before, the box does not start on a MIDI-Start command (classic mode off). Instead it play as long as
any of the pattern-select-notes (C1,D1,E1,F1,G1,A1,B1,C2) or any note in the transposition range (C#2-B5)
is held. When none of the notes are held, the box stops. It also still stops on MIDI-Stop commands.
Start/Stop in Latch Mode
When latch mode is engaged by pressing the Latch Key (D#1) it continues to play until either latch mode is
turned off by pressing the Latch Key again, or until the Stop Key (C#1) is pressed. It also still stops on MIDIStop
commands.
ive tried everything, sending midi notes, dinsync, everything.... its my fave sequencer but i want it to sync from external clock.. so frustrating! it wont even receive din from the syncgen
rasseru
by Dazbo on Sat Mar 08, 2014 5:48 pm
When it says press F# it doesn't mean from the x0x,its gotta be done via midi,like from a keyboard etc
I'm running marOS and I have full midi in,have you tried flashing the OS again? Or tried another OS just to confirm the problem is with marOS?
Dazbo
by tempomaster on Sat Nov 26, 2016 10:34 pm
Bang... Glad that I found this. I'm running MarOS 1.4.1 for now and for the first time, hooked up a keyboard to it and playing in DAW mode.. then I programmed a bunch of stuff and tried to get it to work with midi start and nothing!
hooked the keyboard back up, pressed F#1 and everything works again.
(I know it's an old thread, but what the heck)
tempomaster
