setting the VCF right
x0x0x0x0x0x
Chris72160
Post by Chris72160 »
which tone should be pressed/ which voltage should be applied, while the VCF should be tuned at 500Hz?
C1/ 65,4Hz, 2V
or
A/ 110Hz, ?V
or
C2/ 130,8Hz, 3V
In the original TB-303 manual is no specification regarding the tonehigh.
Greetz Chris
antto
Re: setting the VCF right
Post by antto »
it shows the sawtooth wavelength as 15ms, which is 66.6Hz, so 2 volts
Chris72160
Where is it shown exactly?
Greetz Chris
antto
Post by antto »
on the actual circuit schematic right next to the VCF section (TP6)
Chris72160
Found it! Great. :)
Thank you very much.
The informations here seem to be wrong, because lower C is not 3v:
http://www.ladyada.net/wiki/x0x/vcftesting
Greetz Chris
Return to “General x0xing”
