Button Not working in Face recognition Treasure Box Project
by priyank1 on Fri Apr 21, 2017 8:12 am
I have been doing this project Treasure box but facing problem in the last phase of the project related to the working of the Push button which is not working for me. I did the exact same connection according to the diagram on Pi 3 but my button wont work.. i used a multimeter to check whether the two wire joining the push button are getting voltage or not but they are getting the voltage. And also cross checked the push Button it works to. when ever i run the box file i get this
Loading training data...
Training data loaded!
Using hardware: PWM
PW increments: 10us
/home/pi/pi-facerec-box-master/hardware.py:19: RuntimeWarning: This channel is already in use, continuing anyway. Use RPIO.setwarnings(False) to disable warnings.
RPIO.setup(config.BUTTON_PIN, RPIO.IN)
Initializing channel 0...
Requesting 139264 bytes
mem_ref 20
bus_addr = 4252872704
virtbase 0x6d635000
after init virtbaseadd_channel_pulse: channel=0, gpio=18, start=0, width=110
init_gpio 18
Running box...
Press button to lock (if unlocked), or unlock if the correct face is detected.
Press Ctrl-C to quit.
I almost tried everything.But the button is not working.
It will be a great help if someone helps me..
priyank1
Re: Button Not working in Face recognition Treasure Box Proj
by adafruit_support_mike on Sun Apr 23, 2017 12:44 am
Post a photo showing your hardware and connections and we'll take a look. 800x600 images usually work best.
by priyank1 on Sun Apr 23, 2017 2:12 am
These are the photos of my circuit.
priyank1
by priyank1 on Sun Apr 23, 2017 2:13 am
continued
priyank1
by adafruit_support_mike on Mon Apr 24, 2017 2:37 am
Those connections look right.
Have you measured the voltage on the RasPi's GPIO pin 25 to make sure it's 3.3v when the switch is open, and drops to 0v when the switch is closed?
by tdicola on Mon Apr 24, 2017 3:09 pm
Yep double check all the voltages, both at the button and at the Pi GPIO pins. Check if you see 3.3V when open and 0V/ground when the button is pressed. This can help rule out odd issues with wiring, soldering, etc.
tdicola
by farez879 on Mon Jul 17, 2017 7:00 am
hi guys.. i have same problem here..btw i'm a rookie.. i have raspberry pi 2.. i really need your help..
farez879
by adafruit_support_rick on Mon Jul 17, 2017 9:39 am
Have you tried the troubleshooting steps posted above?
Can you post some pictures of your wiring and soldering?
by farez879 on Mon Jul 17, 2017 11:42 am
Yes. i tried every possible solution but it won't work..
Yes. i tried every possible solution but it doesn't work..
farez879
by farez879 on Mon Jul 17, 2017 12:17 pm
i hope you can help me as soon as possible..it's really urgent
farez879
by adafruit_support_mike on Mon Jul 17, 2017 11:37 pm
Does the voltage at the RasPi GPIO pin change when you close the switch?
by farez879 on Tue Jul 18, 2017 12:40 am
i don't have multimeter but i tried ran a test to see if the button working or not and when i run the pyhton script it print 'False' even when the button was not pressed
farez879
by adafruit_support_rick on Tue Jul 18, 2017 9:44 am
farez879 wrote:i don't have multimeter but i tried ran a test to see if the button working or not and when i run the pyhton script it print 'False' even when the button was not pressed
So, your button is stuck in the closed position. Do you have a different button you can try?
