Logger Read Question
by dcrackel on Tue Sep 08, 2009 11:30 pm
I recently picked up a SD module for the Arduino with a ATmega328.
I found the lib for logging very helpfull. Found at http://www.ladyada.net/make/gpsshield/download.html
However I would like to be able to read from the log file also.
In AF_SDlog.h I added this sig: uint8_t read_file(File f, uint8_t* b, uint8_t num);
#ifndef _AF_SDLOG_h_
#define _AF_SDLOG_h_
#include "sd_raw.h"
#include "sd_raw_config.h"
#include "sd-reader_config.h"
#include "partition.h"
#include "partition_config.h"
#include "fat16.h"
typedef struct fat16_file_struct * File;
class AF_SDLog {
  struct partition_struct *partition;
  struct fat16_fs_struct* fs;
  struct fat16_dir_struct* dd;
  struct fat16_dir_entry_struct file_entry;
 public:
  AF_SDLog(void);
  uint8_t init_card(void);
  uint8_t open_partition(void);
  uint8_t open_filesys(void);
  uint8_t open_dir(char *path);
  uint8_t close_dir(void);
  char *get_next_name_in_dir(void);
  void reset_dir(void);
  File open_file(char *name);
  void close_file(File f);
  uint8_t create_file(char *name);
  uint8_t write_file(File f, uint8_t *b, uint8_t num);
  int16_t read_file(File f, uint8_t* buffer, uint16_t buffer_len);
  uint8_t seek_file(File fd, int32_t *offset, uint8_t whence);
#endif
and in AF_SDLog.cpp I added the function
int16_t AF_SDLog::read_file(File f, uint8_t* buffer, uint16_t buffer_len){
return fat16_read_file(f, buffer, buffer_len);
#include <avr/io.h>
#include "AF_SDLog.h"
#include "fat16.h"
#include "sd_raw.h"
#include <string.h>
#if !USE_DYNAMIC_MEMORY
  struct partition_struct partition_handles[PARTITION_COUNT];
#endif
AF_SDLog::AF_SDLog(void) {
uint8_t AF_SDLog::init_card(void) {
  return sd_raw_init();
uint8_t AF_SDLog::open_partition(void) {
  /* open first partition */
  partition =
    partition_open(sd_raw_read,
         sd_raw_read_interval,
         sd_raw_write,
         sd_raw_write_interval,
         0);
  if(!partition) {
    /* If the partition did not open, assume the storage device
     * is a "superfloppy", i.e. has no MBR.
    partition =
           sd_raw_write,
           -1);
  if(!partition) {
    return 0;
  return 1;
uint8_t AF_SDLog::open_filesys(void) {
  /* open file system */
  fs = fat16_open(partition);
  if(!fs) {
    return 0;
  return 1;
uint8_t AF_SDLog::open_dir(char *path) {
  // Open root directory
  struct fat16_dir_entry_struct rootdirectory;
  fat16_get_dir_entry_of_root(fs, &rootdirectory);
  dd = fat16_open_dir(fs, &rootdirectory);
  if(!dd) {
    return 0;
  return 1;
uint8_t find_file_in_dir(struct fat16_fs_struct* fs, struct fat16_dir_struct* dd, const char* name, struct fat16_dir_entry_struct* dir_entry)
    while(fat16_read_dir(dd, dir_entry))
      if(strcmp(dir_entry->long_name, name) == 0)
     fat16_reset_dir(dd);
     return 1;
    return 0;
struct fat16_file_struct* open_file_in_dir(struct fat16_fs_struct* fs, struct fat16_dir_struct* dd, const char* name)
    if(!find_file_in_dir(fs, dd, name, &file_entry)) {
      //Serial.println("File not found");
        return 0;
    return fat16_open_file(fs, &file_entry);
File AF_SDLog::open_file(char *name) {
  return open_file_in_dir(fs, dd, name);
uint8_t AF_SDLog::create_file(char *name) {
  return fat16_create_file(dd, name, &file_entry);
uint8_t AF_SDLog::write_file(File f, uint8_t *buff, uint8_t siz) {
  return fat16_write_file(f, buff, siz);
uint8_t AF_SDLog::seek_file(File fd, int32_t *offset, uint8_t whence) {
  return  fat16_seek_file(fd, offset, whence);
void AF_SDLog::close_file(File f) {
   fat16_close_file(f);
My program
#include "util.h"
AF_SDLog card;
File f;
#define BUFFSIZE 75
char buffer[BUFFSIZE];
char buffer2[BUFFSIZE];
uint8_t i;
uint8_t j;
#define led1Pin 4
#define led2Pin 3
#define powerPin 2
void setup()
  if (!card.init_card()) {
    putstring_nl("Card init. failed!");
    error(1);
  if (!card.open_partition()) {
    putstring_nl("No partition!");
    error(2);
  if (!card.open_filesys()) {
    putstring_nl("Can't open filesys");
    error(3);
  if (!card.open_dir("/")) {
    putstring_nl("Can't open /");
    error(4);
  strcpy(buffer, "TEST.TXT");
  for (buffer[6] = '0'; buffer[6] <= '9'; buffer[6]++) {
    for (buffer[7] = '0'; buffer[7] <= '9'; buffer[7]++) {
      //putstring("\ntrying to open ");
      //Serial.println(buffer);
      f = card.open_file(buffer);
      if (!f)
        break;
      card.close_file(f);
    if (!f)
      break;
  if(!card.create_file(buffer)) {
    putstring("couldnt create ");
    error(5);
  if (!f) {
    putstring("error opening ");
    card.close_file(f);
    error(6);
  putstring("writing to ");
  putstring_nl("ready!");
  strcpy(buffer, "THIS IS A TEST");
  if(card.write_file(f, (uint8_t *) buffer2, BUFFSIZE) != BUFFSIZE) {
         putstring_nl("can't write!");
  //read Test
  j = 75;
  card.read_file(f,(unsigned char*) buffer2, j);
 // Serial.println("------------------");
  card.close_file(f);
// blink out an error code
void error(uint8_t errno) {
  while(1) {
    for (i=0; i<errno; i++) {
      digitalWrite(led1Pin, HIGH);
      digitalWrite(led2Pin, HIGH);
      delay(100);
      digitalWrite(led1Pin, LOW);
      digitalWrite(led2Pin, LOW);
      delay(100);
    for (; i<10; i++) {
      delay(200);
void loop()
When I compile I get:
o: In function `setup':
C:\Users\admin\AppData\Local\Temp\build29013.tmp/Temporary_9219_1729.cpp:82: undefined reference to `AF_SDLog::read_file(fat16_file_struct*, unsigned char*, unsigned int)'
Couldn't determine program size: C:\Temp\arduino-0015-win\arduino-0015\hardware/tools/avr/bin/avr-size: 'C:\Users\admin\AppData\Local\Temp\build29013.tmp\BasicLogger2.hex': No such file
Any idea's what I can do to resolve this? I don't understand why it things the signatures do not match.
dcrackel
Re: Logger Read Question
by ericzundel on Sat Sep 12, 2009 8:47 pm
did you try casting your third argument (j) to uint16_t? right now it is a uint8_t.
card.read_file(f,(unsigned char*) buffer2, (uint16_t) j);
If that's not it, you might need to make sure you are actually importing the right library. I know when I modified a library once, I had a second copy in the libraries directory with a different directory name and was importing the unmodified version accidentally.
ericzundel
