RaspberryPi.Local refused to connect
by timallenyi111 on Tue May 03, 2016 9:25 pm
So I was working on getting webIDE set up to program my pi, and I initially had it working (kind of). I am pretty new to Linux so I was struggling to get my project set up and running with my repository. At one point when I was tinkering, I think I was trying to reinstall webIDE on my pi, I was doing the step that said log in to my pi remotely with ssh pi@raspberrypi.local. I kept trying different passwords that I thought could be correct, but eventually I tried too many times and it kicked me off. (looking back I don't think I needed to do this step, hints why I didn't have a password). Ever since then, I haven't been able to access webIDE by going to http://raspberrypi.local, however I can still access it through putty. When I try to access webIDE, it says "raspberrypi.local refused to connect" Can anyone point me in the right direction? I am working on a large project with a group, and it would be nice to have webIDE working.
timallenyi111
Re: RaspberryPi.Local refused to connect
by adafruit_support_mike on Thu May 05, 2016 11:39 pm
Have you changed the name of your RasPi?
by jumpstart1981 on Mon Jul 25, 2016 2:17 am
I have the same problem, and no I haven't changed the name. I set the domainname to local.
jumpstart1981
by adafruit_support_mike on Thu Jul 28, 2016 10:18 pm
Changing the machine's name to .local doesn't do anything to the network settings.
Is the avahi daemon running? That's what handles MDNS information, and makes .local name lookups work.
by Steve_Toll on Sat Oct 28, 2017 7:13 pm
I'm having the same problem. I can SSH into raspberrypi.local, but when I try to browse it to use the WebIDE, I always get the "raspberrypi.local refused to connect"
Steve_Toll
by adafruit_support_mike on Sun Oct 29, 2017 12:57 am
First, are you sure the WebIDE server code is running? What response do you get from the command:
sudo service adafruit-webide.sh start
by Steve_Toll on Sun Oct 29, 2017 3:52 am
adafruit_support_mike wrote:First, are you sure the WebIDE server code is running? What response do you get from the command:
I get no response at all.
Steve_Toll
by adafruit_support_mike on Mon Oct 30, 2017 2:06 am
Post the output from:
ps ax
between CODE tags please. We'll see if the server is running.
by bsileo on Mon Feb 12, 2018 11:27 am
Any resolution tot his? I have the same issue. Here is 'ps ax' for me.
  PID TTY      STAT   TIME COMMAND
    1 ?        Ss     3:22 /sbin/init splash
    2 ?        S      0:00 [kthreadd]
    3 ?        S      0:05 [ksoftirqd/0]
    5 ?        S<     0:00 [kworker/0:0H]
    7 ?        S      1:07 [rcu_sched]
    8 ?        S      0:00 [rcu_bh]
    9 ?        S      0:00 [migration/0]
   10 ?        S<     0:00 [lru-add-drain]
   11 ?        S      0:00 [cpuhp/0]
   12 ?        S      0:00 [cpuhp/1]
   13 ?        S      0:00 [migration/1]
   14 ?        S      0:02 [ksoftirqd/1]
   16 ?        S<     0:00 [kworker/1:0H]
   17 ?        S      0:00 [cpuhp/2]
   18 ?        S      0:00 [migration/2]
   19 ?        S      0:04 [ksoftirqd/2]
   21 ?        S<     0:00 [kworker/2:0H]
   22 ?        S      0:00 [cpuhp/3]
   23 ?        S      0:00 [migration/3]
   24 ?        S      0:01 [ksoftirqd/3]
   26 ?        S<     0:00 [kworker/3:0H]
   27 ?        S      0:00 [kdevtmpfs]
   28 ?        S<     0:00 [netns]
   29 ?        S      0:00 [khungtaskd]
   30 ?        S      0:00 [oom_reaper]
   31 ?        S<     0:00 [writeback]
   32 ?        S      0:00 [kcompactd0]
   33 ?        S<     0:00 [crypto]
   34 ?        S<     0:00 [bioset]
   35 ?        S<     0:00 [kblockd]
   36 ?        S<     0:00 [watchdogd]
   38 ?        S<     0:00 [rpciod]
   39 ?        S<     0:00 [xprtiod]
   40 ?        S      0:00 [kswapd0]
   41 ?        S<     0:00 [vmstat]
   42 ?        S<     0:00 [nfsiod]
   52 ?        S<     0:00 [kthrotld]
   53 ?        S<     0:00 [bioset]
   54 ?        S<     0:00 [bioset]
   55 ?        S<     0:00 [bioset]
   56 ?        S<     0:00 [bioset]
   57 ?        S<     0:00 [bioset]
   58 ?        S<     0:00 [bioset]
   59 ?        S<     0:00 [bioset]
   60 ?        S<     0:00 [bioset]
   61 ?        S<     0:00 [bioset]
   62 ?        S<     0:00 [bioset]
   63 ?        S<     0:00 [bioset]
   64 ?        S<     0:00 [bioset]
   65 ?        S<     0:00 [bioset]
   66 ?        S<     0:00 [bioset]
   67 ?        S<     0:00 [bioset]
   68 ?        S<     0:00 [bioset]
   69 ?        S<     0:00 [bioset]
   70 ?        S<     0:00 [bioset]
   71 ?        S<     0:00 [bioset]
   72 ?        S<     0:00 [bioset]
   73 ?        S<     0:00 [bioset]
   74 ?        S<     0:00 [bioset]
   75 ?        S<     0:00 [bioset]
   76 ?        S<     0:00 [bioset]
   77 ?        S<     0:00 [iscsi_eh]
   78 ?        S<     0:00 [dwc_otg]
   80 ?        S<     0:00 [DWC Notificatio]
   81 ?        S<     0:00 [VCHIQ-0]
   82 ?        S<     0:00 [VCHIQr-0]
   83 ?        S<     0:00 [VCHIQs-0]
   84 ?        S      0:00 [VCHIQka-0]
   85 ?        S<     0:00 [SMIO]
   87 ?        S      1:37 [irq/92-mmc1]
   90 ?        S<     0:00 [bioset]
   91 ?        S      0:05 [mmcqd/0]
   92 ?        S      0:02 [jbd2/mmcblk0p2-]
   93 ?        S<     0:00 [ext4-rsv-conver]
   95 ?        S<     0:00 [ipv6_addrconf]
  117 ?        Ss     0:25 /lib/systemd/systemd-journald
  154 ?        Ss     2:29 /lib/systemd/systemd-udevd
  198 ?        S      6:22 [w1_bus_master1]
  242 ?        S<     0:00 [cfg80211]
  250 ?        S<     0:00 [brcmf_wq/mmc1:0]
  251 ?        S      0:37 [brcmf_wdog/mmc1]
  301 ?        Ssl    0:00 /lib/systemd/systemd-timesyncd
  350 ?        Ss     2:05 avahi-daemon: running [server1.local]
  354 ?        Ss     0:18 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation
  361 ?        SLsl   0:17 /usr/sbin/rngd -r /dev/hwrng
  371 ?        S      0:00 avahi-daemon: chroot helper
  376 ?        Ss     0:01 /usr/sbin/thd --triggers /etc/triggerhappy/triggers.d/ --socket /run/thd.socket --user nobody --deviceglob /dev/input/event*
  379 ?        Ss     0:00 /usr/sbin/atd -f
  384 ?        Ssl    0:04 /usr/sbin/rsyslogd -n
  387 ?        Ss     0:04 /lib/systemd/systemd-logind
  393 ?        Ss     0:00 /usr/sbin/cron -f
  414 ?        Ss     0:02 /sbin/dhcpcd -q -b
  443 ?        Rl   2034:50 /usr/bin/python /home/pi/PondTemperature.py
  466 ?        Ss     0:23 wpa_supplicant -B -c/etc/wpa_supplicant/wpa_supplicant.conf -iwlan0
  513 ?        Ssl   11:46 /usr/bin/dockerd -H fd://
  538 ?        Ss     0:00 /usr/bin/vncserver-x11-serviced -fg
  546 ?        Ss     0:00 /usr/sbin/sshd -D
  556 ?        S<     0:00 [kworker/1:1H]
  558 ?        Sl     0:53 /usr/bin/vncserver-x11-core -service
  570 ?        Ssl    0:00 /usr/sbin/lightdm
  578 tty1     Ss     0:00 /bin/login -f
  579 ?        S<     0:00 [kworker/2:1H]
  670 ?        S<     0:00 [kworker/u9:0]
  671 ?        S<     0:00 [hci0]
  672 ?        S<     0:00 [hci0]
  673 ?        S      0:00 /usr/bin/hciattach /dev/serial1 bcm43xx 921600 noflow - b8:27:eb:15:2b:1a
  679 ?        S<     0:00 [kworker/u9:2]
  680 ?        Ss     0:00 /usr/lib/bluetooth/bluetoothd
  790 ?        Ssl    0:00 /usr/bin/bluealsa
  971 ?        Ss     0:02 /lib/systemd/systemd --user
  985 ?        S      0:00 (sd-pam)
  988 ?        S<     0:00 [krfcommd]
 1008 tty1     S+     0:00 -bash
 1018 tty7     Rsl+   1:30 /usr/lib/xorg/Xorg :0 -seat seat0 -auth /var/run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
 1040 ?        S<     0:00 [kworker/0:1H]
 1066 ?        Ss     0:00 /usr/sbin/exim4 -bd -q30m
 1076 ?        S      0:08 /usr/bin/vncagent service 15
 1201 ?        Sl     0:00 lightdm --session-child 14 17
 1226 ?        Ssl    0:00 /usr/bin/lxsession -s LXDE-pi -e LXDE
 1240 ?        Ss     0:00 /usr/bin/dbus-daemon --session --address=systemd: --nofork --nopidfile --systemd-activation
 1321 ?        Ss     0:00 /usr/bin/ssh-agent x-session-manager
 1328 ?        Ssl    0:00 /usr/lib/gvfs/gvfsd
 1333 ?        Sl     0:00 /usr/lib/gvfs/gvfsd-fuse /run/user/1000/gvfs -f -o big_writes
 1351 ?        S      0:01 openbox --config-file /home/pi/.config/openbox/lxde-pi-rc.xml
 1354 ?        Sl     0:00 lxpolkit
 1361 ?        Sl     5:23 lxpanel --profile LXDE-pi
 1362 ?        Sl     0:01 pcmanfm --desktop --profile LXDE-pi
 1369 ?        Ss     0:00 /usr/bin/ssh-agent -s
 1379 ?        Ssl    0:00 /usr/lib/policykit-1/polkitd --no-debug
 1389 ?        S      0:27 /usr/bin/vncserverui service 16
 1420 ?        Ssl    0:00 /usr/lib/gvfs/gvfs-udisks2-volume-monitor
 1427 ?        Ssl    0:00 /usr/lib/udisks2/udisksd --no-debug
 1434 ?        Ssl    0:00 /usr/lib/menu-cache/menu-cached /run/user/1000/menu-cached-:0
 1443 ?        S      0:00 /usr/bin/vncserverui -statusicon 7
 1453 ?        Ssl    0:00 /usr/lib/gvfs/gvfs-goa-volume-monitor
 1457 ?        Ssl    0:00 /usr/lib/gvfs/gvfs-mtp-volume-monitor
 1461 ?        Ssl    0:00 /usr/lib/gvfs/gvfs-gphoto2-volume-monitor
 1465 ?        Ssl    0:00 /usr/lib/gvfs/gvfs-afc-volume-monitor
 1476 ?        Sl     0:00 /usr/lib/gvfs/gvfsd-trash --spawner :1.4 /org/gtk/gvfs/exec_spaw/0
 1528 ?        S<     0:00 [kworker/3:1H]
 1545 ?        Ssl    8:15 docker-containerd -l unix:///var/run/docker/libcontainerd/docker-containerd.sock --metrics-interval=0 --start-timeout 2m --state-dir /var/run/docker/libcontainerd/containerd --shim docker-containerd-shim --runtime docker-runc
 4069 ?        Ssl    0:00 /usr/lib/packagekit/packagekitd
 4209 ?        S      0:01 [kworker/u8:1]
 5885 ?        S      0:00 [kworker/u8:0]
 6831 ?        Sl     0:04 lxterminal
 6832 ?        S      0:00 gnome-pty-helper
 6833 pts/0    Ss+    0:00 bash
 6941 pts/1    Ss     0:00 bash
 7153 ?        S      0:00 [kworker/2:0]
 7714 ?        S      0:00 [kworker/3:2]
 7936 ?        S      0:00 [kworker/1:0]
 8109 ?        Ssl    0:49 /usr/bin/redis-server 127.0.0.1:6379
 8226 ?        Ssl    0:04 /usr/sbin/ntpd -p /var/run/ntpd.pid -g -u 112:117
 8382 ?        S      0:01 [kworker/u8:2]
 8388 ?        Ss     0:15 restartd
 8660 ?        S      0:00 [kworker/0:1]
 8742 ?        S      0:00 [kworker/2:1]
 8963 ?        S      0:00 [kworker/3:0]
 9285 ?        S      0:00 [kworker/1:1]
 9849 ?        Sl     0:21 /usr/lib/chromium-browser/chromium-browser --disable-quic --enable-fast-unload --enable-tcp-fast-open --disable-gpu-compositing --ppapi-flash-version=26.0.0.151 --enable-pinch --ppapi-flash-path=/usr/lib/chromium-browser/libpepflashplayer.so --ppapi-flash-args=enable_stagevideo_auto=0
 9878 ?        S      0:00 /usr/lib/chromium-browser/chromium-browser --type=zygote --ppapi-flash-path=/usr/lib/chromium-browser/libpepflashplayer.so --ppapi-flash-version=26.0.0.151
 9880 ?        S      0:00 /usr/lib/chromium-browser/chromium-browser --type=zygote --ppapi-flash-path=/usr/lib/chromium-browser/libpepflashplayer.so --ppapi-flash-version=26.0.0.151
10316 ?        Sl     0:00 /usr/lib/chromium-browser/chromium-browser --type=gpu-process --field-trial-handle=16348545550751992340,6905296076583702053,131072 --supports-dual-gpus=false --gpu-driver-bug-workarounds=7,8,10,24,30,69,77 --disable-gl-extensions=GL_KHR_blend_equation_advanced GL_KHR_blend_equation_advanced_coherent --gpu-vendor-id=0x0000 --gpu-device-id=0x0000 --gpu-driver-vendor=Mesa --gpu-driver-version=13.0.6 --gpu-driver-date --service-request-channel-token=123E96C89C10FBEDA9D62C5E81688810
10354 ?        S      0:00 [kworker/2:3]
10435 ?        S      0:00 [kworker/0:0]
11184 ?        S      0:00 [kworker/3:1]
11212 ?        Sl     0:00 /usr/lib/chromium-browser/chromium-browser --type=renderer --disable-gpu-compositing --enable-pinch --field-trial-handle=16348545550751992340,6905296076583702053,131072 --service-pipe-token=FE071B532C66DE7748AA8B48286AC4C0 --lang=en-GB --enable-offline-auto-reload --enable-offline-auto-reload-visible-only --blink-settings=disallowFetchForDocWrittenScriptsInMainFrame=false,disallowFetchForDocWrittenScriptsInMainFrameOnSlowConnections=false,cssExternalScannerNoPreload=false,cssExternalScannerPreload=true --ppapi-flash-args=enable_stagevideo_auto=0 --ppapi-flash-path=/usr/lib/chromium-browser/libpepflashplayer.so --ppapi-flash-version=26.0.0.151 --enable-pinch --num-raster-threads=2 --enable-main-frame-before-activation --content-image-texture-target=0,0,3553;0,1,3553;0,2,3553;0,3,3553;0,4,3553;0,5,3553;0,6,3553;0,7,3553;0,8,3553;0,9,3553;0,10,3553;0,11,3553;0,12,3553;0,13,3553;0,14,3553;0,15,3553;0,16,3553;1,0,3553;1,1,3553;1,2,3553;1,3,3553;1,4,3553;1,5,3553;1,6,3553;1,7,3553;1,8,3553;1,9,3553;1,10,3553;1,11,3553;1,12,3553;1,13,3553;1,14,3553;1,15,3553;1,16,3553;2,0,3553;2,1,3553;2,2,3553;2,3,3553;2,4,3553;2,5,3553;2,6,3553;2,7,3553;2,8,3553;2,9,3553;2,10,3553;2,11,3553;2,12,3553;2,13,3553;2,14,3553;2,15,3553;2,16,3553;3,0,3553;3,1,3553;3,2,3553;3,3,3553;3,4,3553;3,5,3553;3,6,3553;3,7,3553;3,8,3553;3,9,3553;3,10,3553;3,11,3553;3,12,3553;3,13,3553;3,14,3553;3,15,3553;3,16,3553;4,0,3553;4,1,3553;4,2,3553;4,3,3553;4,4,3553;4,5,3553;4,6,3553;4,7,3553;4,8,3553;4,9,3553;4,10,3553;4,11,3553;4,12,3553;4,13,3553;4,14,3553;4,15,3553;4,16,3553 --disable-accelerated-video-decode --disable-gpu-compositing --service-request-channel-token=FE071B532C66DE7748AA8B48286AC4C0 --renderer-client-id=9 --shared-files=v8_natives_data:100,v8_snapshot_data:101
11505 ?        S      0:00 [kworker/1:2]
11765 ?        Sl     0:12 /usr/lib/chromium-browser/chromium-browser --type=renderer --disable-gpu-compositing --enable-pinch --field-trial-handle=16348545550751992340,6905296076583702053,131072 --service-pipe-token=95E7C4DFA9D6C5715A9830962AE19395 --lang=en-GB --extension-process --enable-offline-auto-reload --enable-offline-auto-reload-visible-only --blink-settings=disallowFetchForDocWrittenScriptsInMainFrame=false,disallowFetchForDocWrittenScriptsInMainFrameOnSlowConnections=false,cssExternalScannerNoPreload=false,cssExternalScannerPreload=true --ppapi-flash-args=enable_stagevideo_auto=0 --ppapi-flash-path=/usr/lib/chromium-browser/libpepflashplayer.so --ppapi-flash-version=26.0.0.151 --enable-pinch --num-raster-threads=2 --enable-main-frame-before-activation --content-image-texture-target=0,0,3553;0,1,3553;0,2,3553;0,3,3553;0,4,3553;0,5,3553;0,6,3553;0,7,3553;0,8,3553;0,9,3553;0,10,3553;0,11,3553;0,12,3553;0,13,3553;0,14,3553;0,15,3553;0,16,3553;1,0,3553;1,1,3553;1,2,3553;1,3,3553;1,4,3553;1,5,3553;1,6,3553;1,7,3553;1,8,3553;1,9,3553;1,10,3553;1,11,3553;1,12,3553;1,13,3553;1,14,3553;1,15,3553;1,16,3553;2,0,3553;2,1,3553;2,2,3553;2,3,3553;2,4,3553;2,5,3553;2,6,3553;2,7,3553;2,8,3553;2,9,3553;2,10,3553;2,11,3553;2,12,3553;2,13,3553;2,14,3553;2,15,3553;2,16,3553;3,0,3553;3,1,3553;3,2,3553;3,3,3553;3,4,3553;3,5,3553;3,6,3553;3,7,3553;3,8,3553;3,9,3553;3,10,3553;3,11,3553;3,12,3553;3,13,3553;3,14,3553;3,15,3553;3,16,3553;4,0,3553;4,1,3553;4,2,3553;4,3,3553;4,4,3553;4,5,3553;4,6,3553;4,7,3553;4,8,3553;4,9,3553;4,10,3553;4,11,3553;4,12,3553;4,13,3553;4,14,3553;4,15,3553;4,16,3553 --disable-accelerated-video-decode --disable-gpu-compositing --service-request-channel-token=95E7C4DFA9D6C5715A9830962AE19395 --renderer-client-id=12 --shared-files=v8_natives_data:100,v8_snapshot_data:101
12052 ?        S      0:00 [kworker/2:2]
12120 pts/1    R+     0:00 ps ax
bsileo
by adafruit2 on Tue Feb 13, 2018 12:31 pm
we're actively working on the webide in the last few weeks
https://github.com/adafruit/Adafruit-We ... its/rework
but its not quite ready for re-release (there is a lot that needed updating). we'll post on the blog when its ready to try again!
adafruit2
Site Admin
by bsileo on Tue Feb 13, 2018 1:00 pm
Ok thanks looking forward to seeing the updates.
bsileo
