Powering Adafruit Audio FX Sound Board
by Scott_Bleisath on Thu Dec 06, 2018 2:22 pm
Hi. I just ordered the Adafruit Audio FX Sound Board...
https://learn.adafruit.com/adafruit-aud ... board/tour
I understand that it operates at 3-5 V. I want to use a 9V battery, because there are other components in the project that need 9V. How can I step down the voltage from the battery to the board? Is it as simple as adding a resistor in line? If so, what size resistor should I use? Help and advise is much appreciated!
Scott
Scott_Bleisath
Re: Powering Adafruit Audio FX Sound Board
by adafruit_support_mike on Fri Dec 07, 2018 4:00 am
You can't lower a device's supply voltage with a resistor. Any time the current flowing through the load changes, the voltage across the resistor will change too.
What you need is a voltage regulator like these:
https://www.adafruit.com/product/2164
https://www.adafruit.com/product/2236
by Scott_Bleisath on Sat Dec 08, 2018 7:51 am
OK, thanks Mike!
Scott_Bleisath
