Troubleshooting LED Panel
by gnickels on Sat Jun 08, 2019 8:46 pm
Hello!
I purchased a Raspberry Pi 3 Model B, Matrix Bonnet and 32x32 6mm pitch RGB LED Matrix Panel through Order #2058892-5307492572 on May 19th. I have been waiting for a couple other parts since I received the item which is why I'm making this post almost 3 weeks later.
With these parts I am building my 2nd MLB "out-of-town" scoreboard which I found on Reddit. The build and software is relatively easy and I had essentially zero issues my first time around.
Nonetheless, I am a novice and may botch some verbiage here so let me know if better explanation is needed or feel free to correct my wording and understanding.
To keep it simple: I have attached the 3 pieces and plugged in power however am unable to get the default lighting to turn on the LED board. I cannot tell if the board is defective or if I messed something up.
To not keep it simple: I have attached the bonnet to the raspberry pi via the 40-pin GPIO header. The bonnet is plugged into the LED board input via both the 16-pin IDC cable and .15" pitch 4-pin power cable. The bonnet is plugged in with a 5V 4A (4000mA) switching power supply and the raspberry pi is plugged in with a 5V 2.5A Raspberry Pi 3 B+ Power Supply / Adapter. The raspberry pi's power light comes on and the 5V OK bonnet light comes on and will flicker if I mess with the 4-pin power cables. After some time, nothing happens on the LED board. The first time I did this project about 2 months back the board turned on with flashing "moving" light designs. I originally was provided a 4-pin power cable with circular connector ends which I cut and screwed into the bonnet. I thought maybe I cut it incorrectly / too short and replaced them with spaded connectors and have not seen a difference. I'm not sure how to test if the IDC cable or the LED board is the issue without purchasing another IDC cable. I have not yet installed a microsd card or installed an OS on the raspberry power and simply powered it ( I believe this wasn't required when I tested my first board and it lit up).
Question: How can I confirm if the IDC cable or LED board are the culprit?
Note: I thought it was odd the spade connectors screw in and the inner clamp goes upwards. I didn't remember from the first project if they were supposed to clamp up or down into the bonnet. It's the only way they will screw in tight and hold though so I keep thinking it must be correct.
Pictures are uploaded of all the connected pieces and powered up.
Please let me know if I can provide any more information and what I should try from here!
Full picture of everything plugged in and powered with no LED board lighting
Bonnet is plugged in to raspberry pi, powered, and has IDC cable in place. Spade connectors screwed in.
LED board is powered and data cable plugged in
gnickels
Re: Troubleshooting LED Panel
by adafruit_support_mike on Mon Jun 10, 2019 4:26 am
Have you installed the code necessary to make the Matrix Bonnet do its thing?
https://learn.adafruit.com/adafruit-rgb ... tware-4-16
by gnickels on Wed Jun 12, 2019 8:07 am
Thanks. You're correct.. I misremembered how the first project went and thought there was some acknowledgement from the board that it works. I also initially read the set up instructions but clearly missed the install portion. This can be considered closed.
gnickels
by adafruit_support_mike on Sat Jun 15, 2019 12:28 am
Glad to hear you got things working. Happy hacking!
