Max31850 out puting NaN
Re: Max31850 out puting NaN
by adafruit_support_bill on Wed Jun 05, 2019 2:58 pm
And you see the same thing with the thermocouple connected?
by GreenOlive on Wed Jun 05, 2019 3:18 pm
adafruit_support_bill wrote:And you see the same thing with the thermocouple connected?
Yes, same thing
GreenOlive
by adafruit_support_bill on Wed Jun 05, 2019 3:57 pm
OK. Let's try replacing it. Please contact support@adafruit.com with a link to this thread.
by GreenOlive on Wed Jun 05, 2019 4:07 pm
This board is quite old and could have been damaged. I will find a supplier nearby, thanks for your help and patience I learnt quite a bit. :)
GreenOlive
by GreenOlive on Thu Jun 06, 2019 1:23 pm
hold the two probes apart. That is an open-circuit reading.
Now touch the two probes together. That is a short circuit. This should be "0" or some very small number.
I am curios what could have caused this problem? I got the amplifier a couple months back and everything was working fine, then I updated the libraries for it because the old libraries supposedly didnt support the max 31850 and i was worried about getting an accurate temprature reading. Could this have caused a problem?
GreenOlive
by adafruit_support_bill on Thu Jun 06, 2019 1:33 pm
What library were you using before? If you go back to the previous library, does the problem go away?
by GreenOlive on Sat Jun 08, 2019 2:27 am
adafruit_support_bill wrote:What library were you using before? If you go back to the previous library, does the problem go away?
Very busy at the moment I will double check this when i get a chance
GreenOlive
by GreenOlive on Fri Jun 14, 2019 11:10 am
I went back to the previous libraries and its not outputting any temperatures.
here are the libraries:
https://github.com/milesburton/Arduino-Temperature-Control-Library
https://github.com/PaulStoffregen/OneWire
GreenOlive
by adafruit_support_bill on Fri Jun 14, 2019 12:34 pm
Those are known-good libraries. Sounds like the chip has gone bad.
by GreenOlive on Fri Jun 14, 2019 12:40 pm
adafruit_support_bill wrote:Those are known-good libraries. Sounds like the chip has gone bad.
Sorry I relised i made a typo, I meant to say it is not outputting any ERRORS, I am getting a temperature but im unsure if it is correct as supposedly the libraries dont support the chip
GreenOlive
by adafruit_support_bill on Fri Jun 14, 2019 12:44 pm
Do you have a thermometer or other sensor to compare as a reference?
by GreenOlive on Fri Jun 14, 2019 12:48 pm
adafruit_support_bill wrote:Do you have a thermometer or other sensor to compare as a reference?
No sadly not
GreenOlive
by adafruit_support_bill on Fri Jun 14, 2019 2:34 pm
Looking at the specs, the MAX31850 register layout is pretty much the same as the other one-wire temperature sensors. But it has the added fault bits. So the old driver without MAX31850 support would just report whatever is in the temperature registers and ignore the fault bits.
by GreenOlive on Fri Jun 14, 2019 3:02 pm
adafruit_support_bill wrote:Looking at the specs, the MAX31850 register layout is pretty much the same as the other one-wire temperature sensors. But it has the added fault bits. So the old driver without MAX31850 support would just report whatever is in the temperature registers and ignore the fault bits.
that makes so much sense, a couple weeks back I adjusted the library code to ignore the errors as an experiment and it gave me a temperature. so that explains it. Again thanks for your help!
GreenOlive
