(I'm a noob) Could use some insight from experienced individ
by Microwavedbunny on Tue Aug 13, 2019 9:03 pm
I am planning on 3d printing a button in the same fashion as a staples easy button. I would like to be able to have a switch that when the button is pressed down and released plays a custom sound file through a speaker all of this being inside the enclosed button, I have never done anything like this before and would like some insight on which products would best suit this particular project/idea.
EDIT: I forgot to mention I would like to put a battery inside of it and have a hole to charge the battery on the side of the bottom.
Microwavedbunny
Re: (I'm a noob) Could use some insight from experienced ind
by adafruit_support_mike on Tue Aug 13, 2019 10:47 pm
We have a similar project over in the Learning System that uses a Circuit Playground:
https://learn.adafruit.com/circuitpython-sound-box
You can also use one of our FX Boards to play the sounds:
https://www.adafruit.com/?q=FX%20Board
by Microwavedbunny on Wed Aug 14, 2019 1:49 am
say if i were to use this speaker https://www.adafruit.com/product/1891 and this soundboard https://www.adafruit.com/product/2342 would I need to also use this amp? (https://www.adafruit.com/product/2130)
Microwavedbunny
by adafruit_support_mike on Wed Aug 14, 2019 11:08 pm
Those will work together, yes.
The PAM8302 works with the FX Board, and is good for small speakers.
