4x4 Neotrellis arduino USB midi controller
by LydiaNeko on Thu Nov 07, 2019 5:12 pm
I'm currently racking my brain over how to program a Neotrellis board to output midi to Ableton/Max for live. I'd like to use it as a small Monome but would be happy with basic USB over Midi output at the moment. I'm using an Arduino Uno which might not be ideal and following this guide:
https://www.instructables.com/id/Arduin ... ontroller/
The problem is nothing happens when I press the buttons. I believe this is because its designed for the older Trellis? I've run the basic program for Neotrellis and the buttons and lights all work fine.
Please help
LydiaNeko
Re: 4x4 Neotrellis arduino USB midi controller
by mikeysklar on Thu Nov 07, 2019 10:46 pm
Hi LydiaNeko,
Maybe I should just start with what might be a stupid question for you.
Since you know you want a Trellis based USB midi controller would it make more sense to use the one of our Trellis options that was designed for this?
https://learn.adafruit.com/search?q=trellis%20midis
mikeysklar
by LydiaNeko on Fri Nov 08, 2019 7:21 am
Thanks for your reply, my aim was to get a 16 button controller working with monome max software then build it into a custom controller. It might be a little bit easier to buy the M4 kit but also limited to button numbers and enclosure shape. I might have to step back and use a trellis instead it seems :(. Disappointing that the neotrellis doesn't accept the same code.
LydiaNeko
by mikeysklar on Fri Nov 08, 2019 4:33 pm
Does the UNTZtrument guide meet your needs? It is a 16 button MIDI / USB ready device based on the trellis.
https://learn.adafruit.com/mini-untztru ... controller
mikeysklar
