Adafruit MEMs Microphone SPW2430 Datasheet
by kate1 on Fri Nov 08, 2019 11:01 am
Hi!
I would like to purchase Adafruit Silicon MEMS Microphone Breakout - SPW2430 but I cannot find any datasheet or even a schematic how to connect it. I was wondering if there is any info on the microphone's acoustical parameters? Does anyone know where I can find it?
kate1
Re: Adafruit MEMs Microphone SPW2430 Datasheet
by adafruit_support_mike on Sat Nov 09, 2019 1:49 am
Octopart has a datasheet for the mic:
https://datasheet.octopart.com/SPW2430H ... 840588.pdf
by kate1 on Thu Nov 14, 2019 7:17 am
Yeah, thank you for the mic documentation, I have already found that :D But I was wondering if there is any information about the whole module not only the microphone part - hot to connect it, what is inside it?
kate1
by adafruit_support_bill on Thu Nov 14, 2019 8:04 am
The circuit on the board is just the SPW2430 chip, a voltage regulator and some decoupling capacitors. The complete eagle-cad files including the schematics and board layout files are here: https://github.com/adafruit/Adafruit-SPW2430-PCB
The basic connections are described in the product description: https://www.adafruit.com/product/2716
If you can give us some details about how you plan to use it, we may be able to offer some more specific advice.
Using it is simple: connect GND to ground, Vin to 3.3-5VDC. For the best performance, use the "quietest" supply available (on an Arduino, this would be the 3.3V supply). The audio waveform will come out of the DC pin. The output will have a DC bias of 0.67V so when its perfectly quiet that's what you'll read, there's a little drift. If the audio equipment you're using requires AC coupled audio, you can grab the signal out of the AC pin, which has a 10uF capacitor in series.
The output pin is not designed to drive speakers or anything but the smallest in-ear headphones - you'll need an audio amplifier (such as our 3.7W stereo amp) if you want to connect the amp directly to speakers. If you're connecting to a microcontroller pin, you don't need an amplifier or decoupling capacitor - connect the DC pin directly to the microcontroller ADC pin.
by JReese84 on Thu Nov 14, 2019 8:47 pm
I purchased the Adafruit Silicon MEMS Microphone Breakout SPW2430. Do the output Mic signal have to be processed?
JReese84
by adafruit_support_bill on Thu Nov 14, 2019 8:49 pm
@JReese84 -
From the product description:
by JReese84 on Thu Nov 14, 2019 9:29 pm
What would work best if I wanted to use the mic similar to a wireless microphone? A 3.7W stereo AMP or microcontroller?
JReese84
by adafruit_support_bill on Fri Nov 15, 2019 7:06 am
If you want it to work like a wireless mic, you will need a wireless audio transmitter module that is compatible with your receiver.
We do not carry any wireless audio modules. But a web search for "wireless audio transmitter" should give you plenty of options.
by JReese84 on Fri Nov 15, 2019 7:18 pm
I simply want to receive voice spoken into the mic to come out as spoken. Would you recommend connecting the DC pin on the mic breakout board to a microcontroller to get the voice through a USB connector?
JReese84
by adafruit_support_bill on Sat Nov 16, 2019 1:08 pm
Where do you wan the voice to come out? If you want it to be played on a speaker, you will need an amplifier.
by JReese84 on Tue Nov 19, 2019 5:27 pm
Ok on needing an amplifier if I plan to use speakers. I do not have a preference of where the voice come out. I would just like to know where to make the connection to get the sound. If there are options of getting the voice from more than one place, that would be awesome. Thank you.
JReese84
by adafruit_support_bill on Tue Nov 19, 2019 5:39 pm
The output of the microphone is line-level, so you can connect it directly to the input of the amplifier.
by JReese84 on Tue Nov 19, 2019 6:15 pm
Thanks. Do you happen to offer a MEMS Mic breakout with built-in amplifier?
JReese84
by adafruit_support_bill on Tue Nov 19, 2019 6:57 pm
No. But we have a selection of class-D amplifier modules here: https://www.adafruit.com/?q=class%20d
by JReese84 on Tue Nov 19, 2019 9:34 pm
Thank you.
JReese84
