Tutorial: Running TensorFlow Lite Object Recognition on the
by geekguy on Thu Nov 07, 2019 5:37 pm
I am working through the Running TensorFlow Lite Object Recognition on the Raspberry Pi 4 tutorial and have found a place where things do not work. In the Install TensorFlow 2.0 section, the URL that is used in wget (https://github.com/PINTO0309/Tensorflow-bin/raw/master/tensorflow-2.0.0rc0-cp37-cp37m-linux_armv7l.whl) gets me a 404 not found error. In fact, most of the URLs in the Tensorflow-bin directory of that user do not work.
Can an alternative source of these files be found? It looks like they have progressed to the released file state now.
8-Dale
geekguy
Re: Tutorial: Running TensorFlow Lite Object Recognition on
by mikeysklar on Thu Nov 07, 2019 9:42 pm
Hello 8-Dale,
It looks like the TensorFlow archive had some files shuffled about this week. I think they dropped the rc0 (release candidate prefix). Here are some relevant links to try. Please let me know if this work:
High level overview of files:
60MB RAW file link to the file you were looking for cp37m armv7l:
https://github.com/PINTO0309/Tensorflow ... l?raw=true
mikeysklar
by geekguy on Sun Nov 10, 2019 3:13 am
mikeysklar wrote:Hello 8-Dale,
I have not tried your method, but here is what I had to do to get the right file to install:
1) Clone the repository git@github.com:tensorflow/tensorflow.git
2) Go to the second page of the [url=https://learn.adafruit.com/running-tensorflow-lite-on-the-raspberry-pi-4/initial-setup]Running TensorFlow Lite Object Recognition on the Raspberry Pi 4[/url] tutorial, and do everything there. NOTE: You do NOT have to install the PiTFT Drivers if you do not have a PiTFT installed, because everything will run [b][i]fine[/i][/b] with an HDMI monitor.
3) On the third page of the tutorial, do everything down to, but [b]NOT[/b] including, the Install TensorFlow 2.0 section.
4)Go to https://github.com/PINTO0309/Tensorflow-bin/tensorflow-2.0.0-cp37-cp37m-linux_armv7l.whl in your browser
5) Click the Download button
6) cd to your copy of the tensorflow repository
7) pip3 install <path to the tensorflow-2.0.0-cp37-cp37m-linux_armv7l.whl file>/tensorflow-2.0.0-cp37-cp37m-linux_armv7l.whl
8) pip3 install -e .
9) Follow the rest of the tutorial as it is
8-Dale
geekguy
by mountaintenor on Mon Dec 09, 2019 12:35 pm
I have also run into this problem, reported over a month ago. Could this tutorial be updated so that it works?
mountaintenor
by mikeysklar on Tue Dec 10, 2019 6:54 pm
Did you find this through an Adafruit guide? The tutorial itself on GitHub appears to be owned by Katsuya Hyodo a Japanese developer for Intel.
mikeysklar
by mountaintenor on Wed Dec 11, 2019 10:45 am
I used the Adaftuit guide:
https://learn.adafruit.com/running-tens ... berry-pi-4
and got the 404 error.
mountaintenor
by mikeysklar on Fri Dec 13, 2019 6:58 pm
Gotcha. I updated the guide to reference the valid path for TensorFlow 2.0.
mikeysklar
by PINTO0309 on Sat Dec 14, 2019 7:54 pm
Hi, I am the author of Tensorflow v2 for RaspberryPi installer. Tensorflow upgrades are fast, so my repository top page is refreshed regularly. This is because Github has a 1GB capacity limit. It is safer to include this URL in the procedure as frequent link downs are problematic. All the latest installers and past installers can be downloaded from my GoogleDrive. The shell stored at this URL will not be removed in the future, so you don't have to worry about linking down. The reason for saving the installer on the top page of Github is that some engineers may not have access to GoogleDrive.
https://github.com/PINTO0309/Tensorflow-bin/tree/master/previous_versions
PINTO0309
by mikeysklar on Sun Dec 15, 2019 6:52 pm
Katsuya-san,
Thank you for the response.
If you see any links in our TensorFlow guides you would like updated please let us know. Since we are referencing the WHL file I've not been able to use the previous_verions directory of shell scripts.
mikeysklar
by tbarton782 on Mon Mar 30, 2020 1:26 pm
I got the tutorial (https://learn.adafruit.com/teachable-ma ... a?view=all) to work, until literally the very last line of code ("python3 tests/pitft_teachablemachine.py ../converted_savedmodel.zip"). It errors out saying "python3: can't open file 'tests/pitft_teachablemachine.py': [Errno 2] No such file or directory".
This is a really cool project, and it would be fun to see it work. Did I fail to create a "tests/pitft_teachablemachine.py" file somewhere, or do I need to edit some text somewhere to use my own model?
Thoughts?
Thank you, Tyler
tbarton782
