Attach Solar panel to Mini Pan-Tilt Kit
by David0111 on Sun Nov 10, 2019 8:02 am
Hello
I'm wondering how you attach Medium Solar panel 6V 2W to the Mini Pan-Tilt kit.
David0111
Re: Attach Solar panel to Mini Pan-Tilt Kit
by adafruit_support_bill on Sun Nov 10, 2019 8:28 am
I'd start with some double-sided foam tape and experiment to find the best mounting position for good balance. Once you have determined the ideal balance point, you can make a more permanent attachment with epoxy.
If you don't want to glue directly to the panel, you can make a mounting plate with holes for the 4 screws in the back of the panel. But you should try to keep it lightweight, to avoid overloading the servos..
