100mm Large Arcade Buttons
by BourqueM on Sun Nov 10, 2019 5:59 pm
What is the current draw of the large LED/Push buttons (100mm) Model ADA1185. I'm working on a project that I will need 5 of these, but only one will be lite at a time, and I'm also looking for recommendation on either an Arduino or Adafuit programmable process/control board that will power these LED lights, and be able to interface some sort of a LCD Display.
Thanks in advance
BourqueM
Re: 100mm Large Arcade Buttons
by adafruit_support_mike on Mon Nov 11, 2019 3:25 am
It depends on the voltage. The built-in resistor puts the current at about 25mA when the button is connected to a 12V source.
The LEDs are white IIRC, so you can assume the voltage across the LED will be about 3V when it's lit.
BourqueM wrote:I'm also looking for recommendation on either an Arduino or Adafuit programmable process/control board that will power these LED lights, and be able to interface some sort of a LCD Display.
That would be just about all of them. The Arduino Uno, or our equivalent Metro 328 is a good starter board:
https://www.adafruit.com/product/50
