How to use RF receiver to control a 5v fan?
by tlan on Sun Nov 10, 2019 10:03 pm
Hi all,
I have an RF L4 Receiver, controlled by the remote button control.
When the power is a 3.7v lithium-ion battery, it was able to drive a single LED light, while the voltage across the LED is ~1.9V.
Now I want the remote control to drive a mini fan, with normal working voltage 5v. I was wondering how to make that happen.
The fan motor won't run when I tried it, which I think is due to the voltage being too low.
Please advise on how to achieve this, or is there another RF receiver I can use for higher voltage devices.
Thanks a lot.
tlan
Re: How to use RF receiver to control a 5v fan?
by franklin97355 on Sun Nov 10, 2019 11:59 pm
Do you have 5 volts to run the fan? You could use an optoisolator to take the output of the receiver and convert it to 5 volts.
franklin97355
by tlan on Mon Nov 11, 2019 12:03 am
The fan runs well when it's directly connected to the 3.7v battery, so probably doesn't necessarily need a 5v.
When you say optoisolator, is there a specific model you'd recommend?
Thanks.
tlan
cron
