Adafruit bluefruit nRF52 tensorflow lite support
by yhy12313 on Sun Nov 10, 2019 11:55 pm
I am currently using Adafruit Bluefruit nRF52 board with arduino interface to develop a machine learning application. I used tensorflow lite to do the classification task. The problem right now is the error during the compiling. I posted the github link where you can find all the details of the error and the project. https://github.com/yang12313/tensorflow_lite_nRF52.git
a github bug report link is here: https://github.com/adafruit/Adafruit_nR ... issues/388.
Best,
YHY
yhy12313
Re: Adafruit bluefruit nRF52 tensorflow lite support
by yhy12313 on Fri Nov 15, 2019 11:04 am
UPP
yhy12313
by adafruit_support_mike on Sat Nov 16, 2019 4:15 am
Post the simplest code that demonstrates the error you're getting (between CODE tags please) along with the exact text of any error messages you're getting (again, between CODE tags).
by yhy12313 on Thu Nov 21, 2019 7:54 pm
The code is here:
#include <SparkFunLSM6DS3.h>
#include "model.h"
#include <I2C.h>
#include <Wire.h>
#include <iostream>
#include <bluefruit.h>
#include <TensorFlowLite.h>
#include <tensorflow/lite/experimental/micro/kernels/all_ops_resolver.h>
#include <tensorflow/lite/experimental/micro/micro_error_reporter.h>
#include <tensorflow/lite/experimental/micro/micro_interpreter.h>
#include <tensorflow/lite/schema/schema_generated.h>
#include <tensorflow/lite/version.h>
const int numSamples = 90;
int samplesRead = numSamples;
tflite::MicroErrorReporter tflErrorReporter;
tflite::ops::micro::AllOpsResolver tflOpsResolver;
tflite::ErrorReporter* error_reporter = nullptr;
const tflite::Model* tflModel = nullptr;
tflite::MicroInterpreter* tflInterpreter = nullptr;
TfLiteTensor* tflInputTensor = nullptr;
TfLiteTensor* tflOutputTensor = nullptr;
constexpr int tensorArenaSize = 8 * 1024;
byte tensorArena[tensorArenaSize];
const char* GESTURES[] = {
  "walking",
  "circling",
  "rest",
  "waving"
#define NUM_GESTURES (sizeof(GESTURES) / sizeof(GESTURES[0]));
LSM6DS3 myIMU;
int minVal=265;
int maxVal=402;
int pushButton = 2;
int Pin5 = A4; //analog pin 5
// int flexSensorPin6 = A6; //analog pin 6
int buttonState = 0;
/* IMU data */
int16_t ax, ay, az;
int16_t gx, gy, gz;
int16_t tempRaw;
float accX, accY, accZ;
float gyroX, gyroY, gyroZ;
float smooth_ax, smooth_ay, smooth_az;
float smooth_gx, smooth_gy, smooth_gz;
float gyroXangle, gyroYangle; // Angle calculate using the gyro only
float compAngleX, compAngleY; // Calculated angle using a complementary filter
float kalAngleX, kalAngleY; // Calculated angle using a Kalman filter
uint32_t timer;
uint8_t i2cData[14]; // Buffer for I2C data
// TODO: Make calibration routine
const uint8_t IMUAddress = 0x6B; // AD0 is logic low on the PCB
const uint16_t I2C_TIMEOUT = 1000; // Used to check for errors in I2C communication
uint8_t i2cWrite(uint8_t registerAddress, uint8_t data, bool sendStop) {
  return i2cWrite(registerAddress, &data, 1, sendStop); // Returns 0 on success
uint8_t i2cWrite(uint8_t registerAddress, uint8_t *data, uint8_t length, bool sendStop) {
  Wire.beginTransmission(IMUAddress);
  Wire.write(registerAddress);
  Wire.write(data, length);
  uint8_t rcode = Wire.endTransmission(sendStop); // Returns 0 on success
  if (rcode) {
    Serial.print(F("i2cWrite failed: "));
    Serial.println(rcode);
  return rcode; // See: http://arduino.cc/en/Reference/WireEndTransmission
uint8_t i2cRead(uint8_t registerAddress, uint8_t *data, uint8_t nbytes) {
  uint32_t timeOutTimer;
  uint8_t rcode = Wire.endTransmission(false); // Don't release the bus
  if (rcode) {
    Serial.print(F("i2cRead failed: "));
  Wire.requestFrom(IMUAddress, nbytes, (uint8_t)true); // Send a repeated start and then release the bus after reading
  for (uint8_t i = 0; i < nbytes; i++) {
    if (Wire.available())
      data[i] = Wire.read();
    else {
      timeOutTimer = micros();
      while (((micros() - timeOutTimer) < I2C_TIMEOUT) && !Wire.available());
      else {
        Serial.println(F("i2cRead timeout"));
        return 5; // This error value is not already taken by endTransmission
  return 0; // Success
  // put your setup code here, to run once:
  Serial.begin(38400);
  myIMU.begin();
  pinMode(Pin5, INPUT);
  #if ARDUINO >= 157
    Wire.setClock(400000UL); // Set I2C frequency to 400kHz
    #else
      TWBR = ((F_CPU / 400000UL) - 16) / 2; // Set I2C frequency to 400kHz
  #endif
  // IMU Configuration
  //Over-ride default settings if desired
  myIMU.settings.gyroEnabled = 1;  //Can be 0 or 1
  myIMU.settings.gyroRange = 245;   //Max deg/s.  Can be: 125, 245, 500, 1000, 2000
  myIMU.settings.gyroSampleRate = 833;   //Hz.  Can be: 13, 26, 52, 104, 208, 416, 833, 1666
  myIMU.settings.gyroBandWidth = 50;  //Hz.  Can be: 50, 100, 200, 400;
  myIMU.settings.gyroFifoEnabled = 1;  //Set to include gyro in FIFO
  myIMU.settings.gyroFifoDecimation = 1;  //set 1 for on /1
  myIMU.settings.accelEnabled = 1;
  myIMU.settings.accelRange = 4;      //Max G force readable.  Can be: 2, 4, 8, 16
  myIMU.settings.accelSampleRate = 833;  //Hz.  Can be: 13, 26, 52, 104, 208, 416, 833, 1666, 3332, 6664, 13330
  myIMU.settings.accelBandWidth = 200;  //Hz.  Can be: 50, 100, 200, 400;
  myIMU.settings.accelFifoEnabled = 1;  //Set to include accelerometer in the FIFO
  myIMU.settings.accelFifoDecimation = 1;  //set 1 for on /1
  myIMU.settings.tempEnabled = 0;
  //Non-basic mode settings
  myIMU.settings.commMode = 1;
  //FIFO control settings
  myIMU.settings.fifoThreshold = 100;  //Can be 0 to 4096 (16 bit bytes)
  myIMU.settings.fifoSampleRate = 50;  //Hz.  Can be: 10, 25, 50, 100, 200, 400, 800, 1600, 3300, 6600
  myIMU.settings.fifoModeWord = 6;  //FIFO mode.
  //FIFO mode.  Can be:
  //  0 (Bypass mode, FIFO off)
  //  1 (Stop when full)
  //  3 (Continuous during trigger)
  //  4 (Bypass until trigger)
  //  6 (Continous mode)
  static tflite::MicroErrorReporter micro_error_reporter;  // NOLINT
  error_reporter = &micro_error_reporter;
  // To do list!!!!!!!!!!!!!!!!!
  i2cData[0] = 7; // Set the sample rate to 1000Hz - 8kHz/(7+1) = 1000Hz
  i2cData[1] = 0x00; // Disable FSYNC and set 260 Hz Acc filtering, 256 Hz Gyro filtering, 8 KHz sampling
  i2cData[2] = 0x00; // Set Gyro Full Scale Range to ±250deg/s
  i2cData[3] = 0x00; // Set Accelerometer Full Scale Range to ±2g
  // while(i2cWrite(CTRL1_XL,LSM6DS3_ACC_GYRO_ODR_XL_1660Hz,true));
  // while (i2cWrite(0x19, i2cData, 4, false)); // Write to all four registers at once
  // while (i2cWrite(0x6B, 0x01, true)); // PLL with X axis gyroscope reference and disable sleep mode
  // while (i2cWrite(0x6b,))
  while (i2cRead(LSM6DS3_ACC_GYRO_WHO_AM_I_REG, i2cData, 1));
  if (i2cData[0] != 0x69) { // Read "WHO_AM_I" register
    Serial.print(F("Error reading sensor"));
    while (1);
  delay(100); // Wait for sensor to stabilize
  /* Set kalman and gyro starting angle */
  while (i2cRead(0X28, i2cData, 6));
  accX = (int16_t)((i2cData[0] << 8) | i2cData[1]);
  accY = (int16_t)((i2cData[2] << 8) | i2cData[3]);
  accZ = (int16_t)((i2cData[4] << 8) | i2cData[5]);
  // Source: http://www.freescale.com/files/sensors/doc/app_note/AN3461.pdf eq. 25 and eq. 26
  // atan2 outputs the value of -π to π (radians) - see http://en.wikipedia.org/wiki/Atan2
  // It is then converted from radians to degrees
#ifdef RESTRICT_PITCH // Eq. 25 and 26
  double roll  = atan2(accY, accZ) * RAD_TO_DEG;
  double pitch = atan(-accX / sqrt(accY * accY + accZ * accZ)) * RAD_TO_DEG;
#else // Eq. 28 and 29
  double roll  = atan(accY / sqrt(accX * accX + accZ * accZ)) * RAD_TO_DEG;
  double pitch = atan2(-accX, accZ) * RAD_TO_DEG;
#endif
//  kalmanX.setAngle(roll); // Set starting angle
//  kalmanY.setAngle(pitch);
  gyroXangle = roll;
  gyroYangle = pitch;
  compAngleX = roll;
  compAngleY = pitch;
  timer = micros();
  tflModel = tflite::GetModel(model);
//  if (tflModel->version() != TFLITE_SCHEMA_VERSION) {
//    error_reporter->Report(
//        "Model provided is schema version %d not equal "
//        "to supported version %d.",
////        tflModel->version(), TFLITE_SCHEMA_VERSION);
//    return;
  tflInterpreter = new tflite::MicroInterpreter(tflModel, tflOpsResolver, tensorArena, tensorArenaSize, &tflErrorReporter);
  tflInterpreter->AllocateTensors();
  tflInputTensor = tflInterpreter->input(0);
  tflOutputTensor = tflInterpreter->output(0);
  // put your main code here, to run repeatedly:
  float aX, aY, aZ, gX, gY, gZ;
  while(samplesRead == numSamples){
//    if(myIMU.accelerationAvailable()){
//      myIMU.readAcceleration(aX, aY, aZ);
//      float aSum = fabs(aX) + fabs(aY) + fabs(aZ);
//      if(aSum >= accelerationThreshold){
//        samplesRead = 0;
//        break;
  while(samplesRead < numSamples){
//    // check if new acceleration AND gyroscope data is available
//    aX =  myIMU.readFloatAccelX();
//    aY =  myIMU.readFloatAccelY();
//    aZ =  myIMU.readFloatAccelZ();
//    gX =  myIMU.readFloatGyroX();
//    gY =  myIMU.readFloatGyroY();
//    gZ =  myIMU.readFloatGyroZ();
//    tflInputTensor->data.f[samplesRead * 6 + 0] = aX;
//    tflInputTensor->data.f[samplesRead * 6 + 1] = aY;
//    tflInputTensor->data.f[samplesRead * 6 + 2] = aZ;
//    tflInputTensor->data.f[samplesRead * 6 + 3] = gX;
//    tflInputTensor->data.f[samplesRead * 6 + 4] = gY;
//    tflInputTensor->data.f[samplesRead * 6 + 5] = gZ;
//    samplesRead++;
//    if (samplesRead == numSamples) {
//      // Run inferencing
//      TfLiteStatus invokeStatus = tflInterpreter->Invoke();
//      if (invokeStatus != kTfLiteOk) {
//        Serial.println("Invoke failed!");
//      for (int i = 0; i < NUM_GESTURES; i++) {
//        Serial.print(GESTURES[i]);
//        Serial.print(": ");
//        Serial.println(tflOutputTensor->data.f[i], 6);
//      Serial.println();
and the error message is a bit long:
Arduino: 1.8.9 (Windows 10), Board: "Adafruit Bluefruit Feather nRF52832, 0.2.12 SoftDevice s132 6.1.1, Level 0 (Release)"
In file included from c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\bits\char_traits.h:39:0,
                 from c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\ios:40,
                 from c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\ostream:38,
                 from c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\iostream:39,
                 from D:\Phenoma\Gesture Detection\Gesture-Recognition-master\adafruit\sketch_nov08a\sketch_nov08a.ino:16:
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\bits\stl_algobase.h:243:56: error: macro "min" passed 3 arguments, but takes just 2
     min(const _Tp& __a, const _Tp& __b, _Compare __comp)
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\bits\stl_algobase.h:265:56: error: macro "max" passed 3 arguments, but takes just 2
     max(const _Tp& __a, const _Tp& __b, _Compare __comp)
In file included from c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\bits\stl_algo.h:60:0,
                 from c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\algorithm:62,
                 from C:\Users\neoya\Documents\Arduino\libraries\Arduino_TensorFlowLite\src/third_party/flatbuffers/include/flatbuffers/base.h:45,
                 from C:\Users\neoya\Documents\Arduino\libraries\Arduino_TensorFlowLite\src/third_party/flatbuffers/include/flatbuffers/flatbuffers.h:20,
                 from C:\Users\neoya\Documents\Arduino\libraries\Arduino_TensorFlowLite\src/tensorflow/lite/schema/schema_generated.h:21,
                 from C:\Users\neoya\Documents\Arduino\libraries\Arduino_TensorFlowLite\src/tensorflow/lite/core/api/op_resolver.h:20,
                 from C:\Users\neoya\Documents\Arduino\libraries\Arduino_TensorFlowLite\src/tensorflow/lite/experimental/micro/micro_mutable_op_resolver.h:18,
                 from C:\Users\neoya\Documents\Arduino\libraries\Arduino_TensorFlowLite\src/tensorflow/lite/experimental/micro/kernels/all_ops_resolver.h:16,
                 from D:\Phenoma\Gesture Detection\Gesture-Recognition-master\adafruit\sketch_nov08a\sketch_nov08a.ino:21:
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\bits\algorithmfwd.h:375:41: error: macro "max" passed 3 arguments, but takes just 2
     max(const _Tp&, const _Tp&, _Compare);
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\bits\algorithmfwd.h:388:41: error: macro "min" passed 3 arguments, but takes just 2
     min(const _Tp&, const _Tp&, _Compare);
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\bits\algorithmfwd.h:416:30: error: macro "min" requires 2 arguments, but only 1 given
     min(initializer_list<_Tp>);
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\bits\algorithmfwd.h:426:30: error: macro "max" requires 2 arguments, but only 1 given
     max(initializer_list<_Tp>);
In file included from c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\bits\uniform_int_dist.h:35:0,
                 from c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\bits\stl_algo.h:66,
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\limits:317:11: error: macro "min" requires 2 arguments, but only 1 given
       min() _GLIBCXX_USE_NOEXCEPT { return _Tp(); }
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\limits:321:11: error: macro "max" requires 2 arguments, but only 1 given
       max() _GLIBCXX_USE_NOEXCEPT { return _Tp(); }
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\limits:388:11: error: macro "min" requires 2 arguments, but only 1 given
       min() _GLIBCXX_USE_NOEXCEPT { return false; }
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\limits:391:11: error: macro "max" requires 2 arguments, but only 1 given
       max() _GLIBCXX_USE_NOEXCEPT { return true; }
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\limits:395:38: error: macro "min" requires 2 arguments, but only 1 given
       lowest() noexcept { return min(); }
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\limits:457:11: error: macro "min" requires 2 arguments, but only 1 given
       min() _GLIBCXX_USE_NOEXCEPT { return __glibcxx_min(char); }
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\limits:460:11: error: macro "max" requires 2 arguments, but only 1 given
       max() _GLIBCXX_USE_NOEXCEPT { return __glibcxx_max(char); }
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\limits:464:38: error: macro "min" requires 2 arguments, but only 1 given
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\limits:524:11: error: macro "min" requires 2 arguments, but only 1 given
       min() _GLIBCXX_USE_NOEXCEPT { return -__SCHAR_MAX__ - 1; }
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\limits:527:11: error: macro "max" requires 2 arguments, but only 1 given
       max() _GLIBCXX_USE_NOEXCEPT { return __SCHAR_MAX__; }
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\limits:531:38: error: macro "min" requires 2 arguments, but only 1 given
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\limits:594:11: error: macro "min" requires 2 arguments, but only 1 given
       min() _GLIBCXX_USE_NOEXCEPT { return 0; }
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\limits:597:11: error: macro "max" requires 2 arguments, but only 1 given
       max() _GLIBCXX_USE_NOEXCEPT { return __SCHAR_MAX__ * 2U + 1; }
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\limits:601:38: error: macro "min" requires 2 arguments, but only 1 given
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\limits:667:11: error: macro "min" requires 2 arguments, but only 1 given
       min() _GLIBCXX_USE_NOEXCEPT { return __glibcxx_min (wchar_t); }
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\limits:670:11: error: macro "max" requires 2 arguments, but only 1 given
       max() _GLIBCXX_USE_NOEXCEPT { return __glibcxx_max (wchar_t); }
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\limits:674:38: error: macro "min" requires 2 arguments, but only 1 given
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\limits:736:11: error: macro "min" requires 2 arguments, but only 1 given
       min() noexcept { return __glibcxx_min (char16_t); }
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\limits:739:11: error: macro "max" requires 2 arguments, but only 1 given
       max() noexcept { return __glibcxx_max (char16_t); }
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\limits:742:38: error: macro "min" requires 2 arguments, but only 1 given
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\limits:797:11: error: macro "min" requires 2 arguments, but only 1 given
       min() noexcept { return __glibcxx_min (char32_t); }
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\limits:800:11: error: macro "max" requires 2 arguments, but only 1 given
       max() noexcept { return __glibcxx_max (char32_t); }
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\limits:803:38: error: macro "min" requires 2 arguments, but only 1 given
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\limits:859:11: error: macro "min" requires 2 arguments, but only 1 given
       min() _GLIBCXX_USE_NOEXCEPT { return -__SHRT_MAX__ - 1; }
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\limits:862:11: error: macro "max" requires 2 arguments, but only 1 given
       max() _GLIBCXX_USE_NOEXCEPT { return __SHRT_MAX__; }
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\limits:866:38: error: macro "min" requires 2 arguments, but only 1 given
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\limits:926:11: error: macro "min" requires 2 arguments, but only 1 given
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\limits:929:11: error: macro "max" requires 2 arguments, but only 1 given
       max() _GLIBCXX_USE_NOEXCEPT { return __SHRT_MAX__ * 2U + 1; }
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\limits:933:38: error: macro "min" requires 2 arguments, but only 1 given
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\limits:999:11: error: macro "min" requires 2 arguments, but only 1 given
       min() _GLIBCXX_USE_NOEXCEPT { return -__INT_MAX__ - 1; }
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\limits:1002:11: error: macro "max" requires 2 arguments, but only 1 given
       max() _GLIBCXX_USE_NOEXCEPT { return __INT_MAX__; }
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\limits:1006:38: error: macro "min" requires 2 arguments, but only 1 given
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\limits:1066:11: error: macro "min" requires 2 arguments, but only 1 given
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\limits:1069:11: error: macro "max" requires 2 arguments, but only 1 given
       max() _GLIBCXX_USE_NOEXCEPT { return __INT_MAX__ * 2U + 1; }
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\limits:1073:38: error: macro "min" requires 2 arguments, but only 1 given
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\limits:1138:11: error: macro "min" requires 2 arguments, but only 1 given
       min() _GLIBCXX_USE_NOEXCEPT { return -__LONG_MAX__ - 1; }
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\limits:1141:11: error: macro "max" requires 2 arguments, but only 1 given
       max() _GLIBCXX_USE_NOEXCEPT { return __LONG_MAX__; }
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\limits:1145:38: error: macro "min" requires 2 arguments, but only 1 given
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\limits:1205:11: error: macro "min" requires 2 arguments, but only 1 given
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\limits:1208:11: error: macro "max" requires 2 arguments, but only 1 given
       max() _GLIBCXX_USE_NOEXCEPT { return __LONG_MAX__ * 2UL + 1; }
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\limits:1212:38: error: macro "min" requires 2 arguments, but only 1 given
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\limits:1278:11: error: macro "min" requires 2 arguments, but only 1 given
       min() _GLIBCXX_USE_NOEXCEPT { return -__LONG_LONG_MAX__ - 1; }
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\limits:1281:11: error: macro "max" requires 2 arguments, but only 1 given
       max() _GLIBCXX_USE_NOEXCEPT { return __LONG_LONG_MAX__; }
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\limits:1285:38: error: macro "min" requires 2 arguments, but only 1 given
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\limits:1348:11: error: macro "min" requires 2 arguments, but only 1 given
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\limits:1351:11: error: macro "max" requires 2 arguments, but only 1 given
       max() _GLIBCXX_USE_NOEXCEPT { return __LONG_LONG_MAX__ * 2ULL + 1; }
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\limits:1355:38: error: macro "min" requires 2 arguments, but only 1 given
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\limits:1599:11: error: macro "min" requires 2 arguments, but only 1 given
       min() _GLIBCXX_USE_NOEXCEPT { return __FLT_MIN__; }
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\limits:1602:11: error: macro "max" requires 2 arguments, but only 1 given
       max() _GLIBCXX_USE_NOEXCEPT { return __FLT_MAX__; }
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\limits:1674:11: error: macro "min" requires 2 arguments, but only 1 given
       min() _GLIBCXX_USE_NOEXCEPT { return __DBL_MIN__; }
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\limits:1677:11: error: macro "max" requires 2 arguments, but only 1 given
       max() _GLIBCXX_USE_NOEXCEPT { return __DBL_MAX__; }
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\limits:1749:11: error: macro "min" requires 2 arguments, but only 1 given
       min() _GLIBCXX_USE_NOEXCEPT { return __LDBL_MIN__; }
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\limits:1752:11: error: macro "max" requires 2 arguments, but only 1 given
       max() _GLIBCXX_USE_NOEXCEPT { return __LDBL_MAX__; }
In file included from c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\bits\stl_algo.h:66:0,
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\bits\uniform_int_dist.h:76:56: error: macro "max" requires 2 arguments, but only 1 given
      _IntType __b = std::numeric_limits<_IntType>::max())
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\bits\uniform_int_dist.h:109:57: error: macro "max" requires 2 arguments, but only 1 given
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\bits\uniform_int_dist.h:153:11: error: macro "min" requires 2 arguments, but only 1 given
       min() const
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\bits\uniform_int_dist.h:160:11: error: macro "max" requires 2 arguments, but only 1 given
       max() const
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\bits\uniform_int_dist.h:231:40: error: macro "min" requires 2 arguments, but only 1 given
  const __uctype __urngmin = __urng.min();
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\bits\uniform_int_dist.h:232:40: error: macro "max" requires 2 arguments, but only 1 given
  const __uctype __urngmax = __urng.max();
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\bits\uniform_int_dist.h:300:40: error: macro "min" requires 2 arguments, but only 1 given
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\bits\uniform_int_dist.h:301:40: error: macro "max" requires 2 arguments, but only 1 given
In file included from c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\algorithm:62:0,
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\bits\stl_algo.h:3450:34: error: macro "min" requires 2 arguments, but only 1 given
     min(initializer_list<_Tp> __l)
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\bits\stl_algo.h:3462:34: error: macro "max" requires 2 arguments, but only 1 given
     max(initializer_list<_Tp> __l)
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\bits\stl_algo.h:3815:45: error: macro "max" requires 2 arguments, but only 1 given
       const __uc_type __urngrange = __g.max() - __g.min();
c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\bits\stl_algo.h:3815:57: error: macro "min" requires 2 arguments, but only 1 given
In file included from C:\Users\neoya\Documents\Arduino\libraries\Arduino_TensorFlowLite\src/tensorflow/lite/core/api/op_resolver.h:20:0,
C:\Users\neoya\Documents\Arduino\libraries\Arduino_TensorFlowLite\src/tensorflow/lite/schema/schema_generated.h:2717:41: error: macro "min" requires 2 arguments, but only 1 given
   const flatbuffers::Vector<float> *min() const {
C:\Users\neoya\Documents\Arduino\libraries\Arduino_TensorFlowLite\src/tensorflow/lite/schema/schema_generated.h:2720:41: error: macro "max" requires 2 arguments, but only 1 given
   const flatbuffers::Vector<float> *max() const {
C:\Users\neoya\Documents\Arduino\libraries\Arduino_TensorFlowLite\src/tensorflow/lite/schema/schema_generated.h:2745:38: error: macro "min" requires 2 arguments, but only 1 given
            verifier.VerifyVector(min()) &&
C:\Users\neoya\Documents\Arduino\libraries\Arduino_TensorFlowLite\src/tensorflow/lite/schema/schema_generated.h:2747:38: error: macro "max" requires 2 arguments, but only 1 given
            verifier.VerifyVector(max()) &&
C:\Users\neoya\Documents\Arduino\libraries\Arduino_TensorFlowLite\src/tensorflow/lite/schema/schema_generated.h:6760:17: error: macro "min" requires 2 arguments, but only 1 given
       : min(0.0f),
C:\Users\neoya\Documents\Arduino\libraries\Arduino_TensorFlowLite\src/tensorflow/lite/schema/schema_generated.h:6761:17: error: macro "max" requires 2 arguments, but only 1 given
         max(0.0f),
C:\Users\neoya\Documents\Arduino\libraries\Arduino_TensorFlowLite\src/tensorflow/lite/schema/schema_generated.h:6775:13: error: macro "min" requires 2 arguments, but only 1 given
   float min() const {
C:\Users\neoya\Documents\Arduino\libraries\Arduino_TensorFlowLite\src/tensorflow/lite/schema/schema_generated.h:6778:13: error: macro "max" requires 2 arguments, but only 1 given
   float max() const {
C:\Users\neoya\Documents\Arduino\libraries\Arduino_TensorFlowLite\src/tensorflow/lite/schema/schema_generated.h:9626:19: error: macro "min" requires 2 arguments, but only 1 given
   { auto _e = min(); if (_e) { _o->min.resize(_e->size()); for (flatbuffers::uoffset_t _i = 0; _i < _e->size(); _i++) { _o->min[_i] = _e->Get(_i); } } };
C:\Users\neoya\Documents\Arduino\libraries\Arduino_TensorFlowLite\src/tensorflow/lite/schema/schema_generated.h:9627:19: error: macro "max" requires 2 arguments, but only 1 given
   { auto _e = max(); if (_e) { _o->max.resize(_e->size()); for (flatbuffers::uoffset_t _i = 0; _i < _e->size(); _i++) { _o->max[_i] = _e->Get(_i); } } };
C:\Users\neoya\Documents\Arduino\libraries\Arduino_TensorFlowLite\src/tensorflow/lite/schema/schema_generated.h:11470:19: error: macro "min" requires 2 arguments, but only 1 given
   { auto _e = min(); _o->min = _e; };
C:\Users\neoya\Documents\Arduino\libraries\Arduino_TensorFlowLite\src/tensorflow/lite/schema/schema_generated.h:11471:19: error: macro "max" requires 2 arguments, but only 1 given
   { auto _e = max(); _o->max = _e; };
exit status 1
Error compiling for board Adafruit Bluefruit Feather nRF52832.
yhy12313
by yhy12313 on Fri Nov 22, 2019 1:34 pm
I tried the adafruit tensorflow lite example "Magic wand" but it has the same error as the last post. Also, I tried the "Hello World " sketchbook and it gave the same error again. I guess the problem comes from the lack support of tensorflow lite in adafruit bluefruit.
Since the adafruit Bluefruit is a very good platform to develop BLE solution. I highly recommend the support team to add tensorflow lite support on bluefruit.
The error code is attached here:
                 from c:\users\neoya\appdata\local\arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\string:40,
                 from C:\Users\neoya\Documents\Arduino\libraries\Arduino_TensorFlowLite\src/third_party/flatbuffers/include/flatbuffers/base.h:41,
                 from C:\Users\neoya\Documents\Arduino\libraries\Arduino_TensorFlowLite\examples\hello_world\hello_world.ino:23:
       min() const
       max() const
       : min(0.0f),
         max(0.0f),
   float min() const {
   float max() const {
exit status 1
yhy12313
