Adafruit Industries, Essential service and business: NYC – Executive Order 202.6 - Read more.
Adafruit SD Card Data Logger Shield
by jonathanwarecd34 on Sun Mar 15, 2020 2:37 pm
Hi, I bought an SD Card Data Logger Shield with my Metro 328, which didn't work upon my initial testing, and I am trying to use the shield with an actual Arduino Uno. I am using the RTClib example for the PCF8523, and it is giving me some really weird stuff. Here is the code.
__________________________________________________________________________________________________________________________________________
// Date and time functions using a PCF8523 RTC connected via I2C and Wire lib
#include "RTClib.h"
#include <Wire.h>
RTC_PCF8523 rtc;
char daysOfTheWeek[7][12] = {"Sunday", "Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday"};
void setup () {
  while (!Serial) {
    delay(1);  // for Leonardo/Micro/Zero
  Serial.begin(57600);
  if (! rtc.begin()) {
    Serial.println("Couldn't find RTC");
    while (1);
  if (! rtc.initialized()) {
    Serial.println("RTC is NOT running!");
    // following line sets the RTC to the date & time this sketch was compiled
    rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
    // This line sets the RTC with an explicit date & time, for example to set
    // January 21, 2014 at 3am you would call:
    rtc.adjust(DateTime(2020, 3, 15, 1, 24, 0));
void loop () {
    DateTime now = rtc.now();
    Serial.print(now.year(), DEC);
    Serial.print('/');
    Serial.print(now.month(), DEC);
    Serial.print('/');
    Serial.print(now.day(), DEC);
    Serial.print(" (");
    Serial.print(daysOfTheWeek[now.dayOfTheWeek()]);
    Serial.print(") ");
    Serial.print(now.hour(), DEC);
    Serial.print(':');
    Serial.print(now.minute(), DEC);
    Serial.print(':');
    Serial.print(now.second(), DEC);
    Serial.println();
    Serial.print(" since midnight 1/1/1970 = ");
    Serial.print(now.unixtime());
    Serial.print("s = ");
    Serial.print(now.unixtime() / 86400L);
    Serial.println("d");
    // calculate a date which is 7 days, 12 hours and 30 seconds into the future
    DateTime future (now + TimeSpan(7,12,30,6));
    Serial.print(" now + 7d + 12h + 30m + 6s: ");
    Serial.print(future.year(), DEC);
    Serial.print('/');
    Serial.print(future.month(), DEC);
    Serial.print('/');
    Serial.print(future.day(), DEC);
    Serial.print(' ');
    Serial.print(future.hour(), DEC);
    Serial.print(':');
    Serial.print(future.minute(), DEC);
    Serial.print(':');
    Serial.print(future.second(), DEC);
    Serial.println();
    Serial.println();
    delay(3000);
Here is what the serial monitor is outputting.
[img]
[/img]
jonathanwarecd34
Re: Adafruit SD Card Data Logger Shield
by adafruit_support_bill on Sun Mar 15, 2020 3:04 pm
Make sure that your serial monitor is also set at 57600 baud.
by jonathanwarecd34 on Thu Mar 19, 2020 4:13 pm
Thank you so much, Bill. That worked. Is there a specific reason that the baud rate is set to 57600?
Jonathan
jonathanwarecd34
by jonathanwarecd34 on Thu Mar 19, 2020 5:44 pm
Hi, again. I am also having trouble with the CardInfo example in the Arduino IDE. Here is the code that I am compiling and uploading.
  SD card test
  This example shows how use the utility libraries on which the'
  SD library is based in order to get info about your SD card.
  Very useful for testing a card when you're not sure whether its working or not.
  The circuit:
    SD card attached to SPI bus as follows:
 ** MOSI - pin 11 on Arduino Uno/Duemilanove/Diecimila
 ** MISO - pin 12 on Arduino Uno/Duemilanove/Diecimila
 ** CLK - pin 13 on Arduino Uno/Duemilanove/Diecimila
 ** CS - depends on your SD card shield or module.
       Pin 4 used here for consistency with other Arduino examples
  created  28 Mar 2011
  by Limor Fried
  modified 9 Apr 2012
  by Tom Igoe
// include the SD library:
#include <SPI.h>
#include <SD.h>
// set up variables using the SD utility library functions:
Sd2Card card;
SdVolume volume;
SdFile root;
// change this to match your SD shield or module;
// Arduino Ethernet shield: pin 4
// Adafruit SD shields and modules: pin 10
// Sparkfun SD shield: pin 8
// MKRZero SD: SDCARD_SS_PIN
const int chipSelect = 10;
  // Open serial communications and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  Serial.print("\nInitializing SD card...");
  // we'll use the initialization code from the utility libraries
  // since we're just testing if the card is working!
  if (!card.init(SPI_HALF_SPEED, chipSelect)) {
    Serial.println("initialization failed. Things to check:");
    Serial.println("* is a card inserted?");
    Serial.println("* is your wiring correct?");
    Serial.println("* did you change the chipSelect pin to match your shield or module?");
    while (1);
  } else {
    Serial.println("Wiring is correct and a card is present.");
  // print the type of card
  Serial.println();
  Serial.print("Card type:         ");
  switch (card.type()) {
    case SD_CARD_TYPE_SD1:
      Serial.println("SD1");
      break;
    case SD_CARD_TYPE_SD2:
      Serial.println("SD2");
      break;
    case SD_CARD_TYPE_SDHC:
      Serial.println("SDHC");
      break;
    default:
      Serial.println("Unknown");
  // Now we will try to open the 'volume'/'partition' - it should be FAT16 or FAT32
  if (!volume.init(card)) {
    Serial.println("Could not find FAT16/FAT32 partition.\nMake sure you've formatted the card");
    while (1);
  Serial.print("Clusters:          ");
  Serial.println(volume.clusterCount());
  Serial.print("Blocks x Cluster:  ");
  Serial.println(volume.blocksPerCluster());
  Serial.print("Total Blocks:      ");
  Serial.println(volume.blocksPerCluster() * volume.clusterCount());
  Serial.println();
  // print the type and size of the first FAT-type volume
  uint32_t volumesize;
  Serial.print("Volume type is:    FAT");
  Serial.println(volume.fatType(), DEC);
  volumesize = volume.blocksPerCluster();    // clusters are collections of blocks
  volumesize *= volume.clusterCount();       // we'll have a lot of clusters
  volumesize /= 2;                           // SD card blocks are always 512 bytes (2 blocks are 1KB)
  Serial.print("Volume size (Kb):  ");
  Serial.println(volumesize);
  Serial.print("Volume size (Mb):  ");
  volumesize /= 1024;
  Serial.print("Volume size (Gb):  ");
  Serial.println((float)volumesize / 1024.0);
  Serial.println("\nFiles found on the card (name, date and size in bytes): ");
  root.openRoot(volume);
  // list all files in the card with date and size
  root.ls(LS_R | LS_DATE | LS_SIZE);
void loop(void) {
In addition, here is a picture of what the serial monitor is outputting.
Screenshot (141).png (171.64 KiB) Viewed 62 times
jonathanwarecd34
by adafruit_support_bill on Thu Mar 19, 2020 6:29 pm
Have you formatted the card for a FAT32 file system?
This is the recommended formatter: https://www.sdcard.org/downloads/formatter_3/
by jonathanwarecd34 on Mon Mar 23, 2020 11:45 pm
I did not see anywhere that I could choose FAT32 file system. The Card type is SDXC and I chose quick format. I tried the example, was unsuccessful.
jonathanwarecd34
by adafruit_support_bill on Tue Mar 24, 2020 6:03 am
SDXC uses a proprietary exFAT format and is not supported by the SD library. I don't think that the SD association formatter handles them.
You can try Bill Greiman's SDFormatter here: https://github.com/greiman/SdFat/blob/m ... matter.ino
Otherwise, try an SD or SDHC card.
by jonathanwarecd34 on Thu Mar 26, 2020 2:45 am
Do I just run that code in the Arduino IDE, or how do I do that?
jonathanwarecd34
by adafruit_support_bill on Thu Mar 26, 2020 5:45 am
I believe that is an Arduino sketch. So you should be able to just run that in the IDE.
