3.5" 2050 TFT LCD
3.5" 2050 TFT LCD
by victorbramhall on Mon May 03, 2021 3:03 pm
I have two recently purchased displays. They both work perfectly with the exception of the Touchscreen. Included is the documentation used for the wiring and connections. Would like some help getting them working.
Thank you,
Victor Bramhall
320x480 Touch.PNG (304.6 KiB) Viewed 82 times
Schematic_ADAFRUIT 3.5 LCD CLOCK v3.1_2021-04-30.png (82.84 KiB) Viewed 82 times
victorbramhall
Re: 3.5" 2050 TFT LCD
by adafruit_support_mike on Tue May 04, 2021 1:52 am
Post a photo showing your actual hardware and connections and we'll take a look. 800x600 images usually work best.
by victorbramhall on Tue May 04, 2021 7:40 am
Thank you,
Victor
victorbramhall
by victorbramhall on Tue May 04, 2021 7:52 am
victorbramhall
by adafruit_support_mike on Tue May 04, 2021 10:46 pm
What pin numbers are you using in the code when you create the TouchScreen object?
by victorbramhall on Wed May 05, 2021 6:29 am
Y+ - A0
X+ - 32
Y- - 15
X- - A1
325 ohms
victorbramhall
by adafruit_support_mike on Thu May 06, 2021 1:33 am
Those look good, thank you.
With power disconnected from everything, what resistance do you measure between the X+/X- and Y+/Y- pins (D32 to A1, and A0 to D15)?
by victorbramhall on Sat May 08, 2021 6:18 am
325 ohms
victorbramhall
by victorbramhall on Sat May 08, 2021 6:25 am
Only 1/4 of the touchscreen in the y axis is sensitive. But I can adjust the screen response with the map() function to full screen. Both displays that I have react the same way.
victorbramhall
