Zero_Timer bug.
Zero_Timer bug.
by smp on Wed Jun 09, 2021 9:39 am
Couldn't find any more appropriate place to put this...
Found (what I believe to be) a bug in the Zero_Timer-master code:
*** 442,449 ****
return false;
_pwm_channel[channum].enabled = true;
! _pwm_channel[channum].pin_out = pin;
_pwm_channel[channum].pin_mux = pinmux;
// re-init
--- 454,467 ----
return false;
! _pwm_channel[channum].pin_out = pinout;
smp
Re: Zero_Timer bug.
by adafruit_support_mike on Thu Jun 10, 2021 7:41 pm
I'll have the folks who handle that library check it out. Thanks!
To help them along, what problem does the existing code cause, and how does the patch above fix it?
Re: Zero_Timer bug.
by smp on Thu Jun 10, 2021 10:28 pm
I haven't even gotten it to work yet, but if you read the code in that routine from top to bottom its obvious.
smp
