Wiring Help. Neopixel connected to a reversible 3 pin connec
by wassabi on Wed Jun 23, 2021 12:26 pm
I found these really cool 3 pin magnetic connectors and want to use them to connect to WS2812B neopixels. Problem is that the connectors are not keyed and could be plugged in backwards.
Some basic info here: https://electronics.stackexchange.com/q ... ors-called
Which wiring combo should be safe for wiring to a neopixel? I have read that the WS2812B have reverse voltage protection, but I don't want to trust that.
   FWD  REV
1  VCC  GND
2  DATA DATA
3  GND  VCC
KABOOM?
   FWD  REV
1  DATA GND
2  VCC  VCC
3  GND  DATA
OK?
   FWD  REV
1  DATA VCC
2  GND  GND
3  VCC  DATA
OK?
wassabi
Re: Wiring Help. Neopixel connected to a reversible 3 pin co
by adafruit_support_bill on Wed Jun 23, 2021 8:15 pm
They do not.
The chip specs say that you should not connect the DATA signal to anything less than GND or greater than VCC. I don't believe that there are any safe reversible combinations that would guarantee that.
by wassabi on Thu Jun 24, 2021 8:24 am
In that case. How about a resistor on the data pin, so the neopixel won’t be inadvertently powered by a data connected to ground.
The data sheet says 1 µA for the max current draw of the data pin. So I am thinking a 100k to 1M ohm.
wassabi
by adafruit_support_bill on Thu Jun 24, 2021 3:38 pm
You can try that to see if it works. For longer runs we recommend something in the 300-500 ohm range as a termination resistor for longer runs.
