Defective MAX31856 Breakout Board
mmcphers
Post by mmcphers »
Order# 2586014-5524679380 (directly from the Adafruit Website)
I purchased three MAX318566 Breakout Boards and after soldering the pins, I tested them using an Arduino Mega and the provided code as outlined on the Testing page. After repeated testing, I found two of the three to be working wonderfully and the third to be defective. I am in need of replacement so as to get readings from three T-type Thermocouples for my Mechanical Engineering Research project at Trinity College. Thank you in advance for your help.
**My apologies I had to crop my photo considerably to satisfy the 1 MB limit.**
mikeysklar
Re: Defective MAX31856 Breakout Board
Post by mikeysklar »
Thank you for the quality photo.
This looks like a potential soldering issue as there is not good flow from the pin tops to the via. Can you go over the solder points on the "defective" MAX31856 and try it again.
When was this order placed?
mmcphers
Post by mmcphers »
The order was placed two Wednesdays ago on 6/9/2021. I had in fact improved the soldering job on all three just after the picture was taken, but the one I believe is defective still is not operating at all.
adafruit2
Post by adafruit2 »
take a new photo - the one above has all cold solder joints, they are not good.
mmcphers
Post by mmcphers »
I made the same assessment that my initial soldering was poor, I improved them all to the degree that can be seen in the attached photo but to no avail.
mikeysklar
Thank you for the updated photo. The soldering is better.
Normally I'd ask for a photo of the unit wired up and the example code you are running, but since the other two work and this one continues to be an issue let's for you let's swap it.
Please e-mail [email protected] requresting a replacement. Include your original order# and link to this forum thread.
mmcphers
Post by mmcphers »
Thank you both for your help, I've just sent the email. Your patience is much appreciated.
