Adafruit Soundboard Found 0 Files
by msf567 on Mon Jul 26, 2021 4:54 pm
Hi, so I've seen this issue posted a bunch here and I have not been able to find a solution.
Attached is my wiring, I'm running the menucommands code, and I can refresh and see the menu commands, the soundboard is recognized, and there are confirmed files on the device, the demo files to be exact.
*When I query the file list however, it says 0 files found.*
Whats the issue? Is my wiring wrong? Do I need to configure my arudino to use pins 5 and 6 for tx/rx beyond just uploading the menucommands sketch?
msf567
Re: Adafruit Soundboard Found 0 Files
by Frank54324 on Mon Jul 26, 2021 8:45 pm
I'm in the process of working with this board but youre ahead of me, I'm trying to do kind of just a read display first. How did you try and load the sound files on there? How did you query the files, can you just link to the guide?
I can actually tell you something constructive, the arduino uno doesn't have as good as memory capability as good as the adafruit board they recommend. hopefully someone else can comment tho
Frank54324
by dastels on Mon Jul 26, 2021 8:48 pm
The wiring looks ok. And the board is being found.
Can you post a list of what's on the board (from the USB connected device)?
I just hooked it up and loaded/ran the menucommands sketch without modification, confirming that L gives me the list of what's on my sound board.
dastels
Frank54324 wrote:I'm in the process of working with this board but youre ahead of me. How did you try and load the sound files on there? How did you query the files, can you just link to the guide?
Please see the guide at https://learn.adafruit.com/adafruit-audio-fx-sound-board.
dastels
by msf567 on Tue Jul 27, 2021 10:35 am
dastels wrote:Can you post a list of what's on the board (from the USB connected device)?
What do you mean?
It just doesnt give me any files.
Now btw, I cant even mount it in windows, it seems the sound board is stuck in some random broken state...
msf567
by dastels on Tue Jul 27, 2021 10:41 am
I meant from, I guess in your case, Windows Explorer.
Have you rtried resetting the board while connected? Have you tried a different USB port? Have you confirmed that the cable at the moment is a data cable?
dastels
by msf567 on Tue Jul 27, 2021 10:51 am
Different USB port fixed it!
Cheers!
msf567
