adafruit PN532 RFID/NFC Shield
by officialPiUser on Thu Jul 22, 2021 8:53 am
I recently bought the adafruit PN532 RFID/NFC Shield.
When I plug it in the power led does not light up.
The test programm from the adafruit tutorial doesen't work as well.
It says that no SPI connection is found.
I also measured with a multimeter that the 3,3V are connected right, but the board didn’t respond.
What can I do?
officialPiUser
Re: adafruit PN532 RFID/NFC Shield
by adafruit_support_mike on Sun Aug 01, 2021 9:48 pm
Post a photo showing your hardware and connections and we'll take a look. 800x600 images usually work best.
by officialPiUser on Fri Aug 06, 2021 12:54 am
On the other side I have connected the NFC Reader with a Raspberry Pi 3B+ via Jumper Wire.
Pi 3V to3.3V
Pi GND to GND
Pi MOSI to MOSI
Pi MISO to MISO
Pi SCLK to SCK
Pi D5 to SS
officialPiUser
by adafruit_support_mike on Sat Aug 07, 2021 8:22 pm
As a sanity check, what voltage do you see between the 3.3V and GND pins parallel to the ones with the wire connections?
by officialPiUser on Mon Aug 09, 2021 3:08 am
Measuring with the multimeter I see the 3.3V at the free conection points.
officialPiUser
by adafruit_support_mike on Mon Aug 09, 2021 12:20 pm
Okay, that confirms basic power in the wiring.
Try connecting power to the 5V pin instead of the 3.3V pin. See if that makes the power LED light.
by officialPiUser on Tue Aug 10, 2021 9:37 am
It worked.
The power LED turned on.
officialPiUser
by aahmed1 on Tue Aug 10, 2021 4:16 pm
officialPiUser wrote:It worked.
I am having the same connections you have and I got the shield to be powered on but the device is not recognized on my PI
is it working with you ?
aahmed1
by adafruit_support_mike on Tue Aug 10, 2021 5:02 pm
That was my next question:
@officialPiUser: now that the PN532 breakout's power is good, can you control it from the RasPi?
by officialPiUser on Wed Aug 11, 2021 12:47 am
Yes.
I can controll it with the Pi and it recognizes the NFC Tags.
officialPiUser
by adafruit_support_mike on Wed Aug 11, 2021 1:47 pm
Glad to hear you got it working. Happy hacking!
by aahmed1 on Wed Aug 11, 2021 2:42 pm
officialPiUser wrote:Yes.
I have been trying to get it to work for a while now
I have the same connection you have
Pi 5 v to 5v
Pi Gnd to Gnd
Pi MOSI to MOSI
Pi MISO to MISO
PI SCLK to SCK
PI D5 to SS
and SEL0 and SEL1 are both closed or soldered
but I have the busy led always on I do not know why and the PN532 is not detected.
aahmed1
by adafruit_support_mike on Wed Aug 11, 2021 7:27 pm
Post a photo showing your hardware and connections and we’ll take a look. 800x600 images usually work best.
cron
