Appears shorted
Appears shorted
by MikePOP on Mon Aug 02, 2021 8:34 am
I purchased a Inductive charging set - 3.3v @500ma. I connected it to a current limited supply set to 9v. It drew over 1A (the limit I had set), and the current limiting on the supply dropped it to 1.8V. There apparently is a short somewhere on the board. How can I submit for a replacement item. Order number 262151.
MikePOP
Re: Appears shorted
by adafruit_support_mike on Mon Aug 02, 2021 10:18 pm
That is unusually high. For the sake of sanity testing, could you post a photo of how you had things connected when you did the test please?
800x600 images usually work best.
Re: Appears shorted
by MikePOP on Tue Aug 03, 2021 8:58 am
I have attached some photos. I applied power briefly with limiting removed to show the high current draw. The 5 ohms across the xkt-335 seems low.
Reading across XKT-335 with no power applied
Power applied briefy
Connection to device with no receiver coil nearby
MikePOP
Re: Appears shorted
by adafruit_support_mike on Tue Aug 03, 2021 4:42 pm
Thanks. Does any component on the PCB get hot?
Re: Appears shorted
by MikePOP on Tue Aug 03, 2021 4:47 pm
Yes, If I leave power applied the entire PCB gets to hot to touch within a few seconds.
MikePOP
Re: Appears shorted
by adafruit_support_mike on Tue Aug 03, 2021 5:19 pm
That’s a shorted component, thank you.
Send a note containig a link to this page and your order number to support@adafruit.com. The folks there will get you replacement.
